Using TeeRecompile
BruceC
Using TeeRecompile
Post by BruceC » Wed May 25, 2016 1:43 pm
TeeChartVCLFMXSOURCE-2016.18
Need some help please.
I have 4 IDE's installed XE2, XE7, Seattle & Berlin.
When running TeeRecompile all compile ok except for XE2 which fails with the error message " Required package "IndyProtocols not found" because of the version of Indy installed.
If I then change all relevant XE2 DPK's in the source folder to use IndyProtocols916 it then fails with the error message "Required package 'IndyProtocols916' not found".
But these do exists. Can you please tell me where TeeRecompile is looking for these?
Also are there any instructions on how to do this manually?
Bruce
BruceC
Re: Using TeeRecompile
Post by BruceC » Thu May 26, 2016 10:48 am
Sorry. I of course meant IndyProtocols160!
Post by Yeray » Thu May 26, 2016 12:08 pm
Hi Bruce,
TeeRecompile calls the IDE compiler but it probably doesn't find your Indy installation path.
To manually recompile the TeeChart packages, you can try to build open the .groupproj attached and build all the packages (with the corrected references). Then you should be able to install the Dcl* packages into your IDE.
Tee9RADXE2.zip
(956 Bytes) Downloaded 644 times
BruceC
Post by BruceC » Thu May 26, 2016 2:14 pm
Thanks. I get so far but
Procedure TTeeCanvas.TextOut(const X,Y:TCoordinate; const Text:String; AllowHtml:Boolean);
  if AllowHtml then
     HtmlTextOut(Self,{$IFDEF FMX}Round{$ENDIF}(X),{$IFDEF FMX}Round{$ENDIF}(Y),Text)
     TextOut(X,Y,Text);
doesn't compile. I get the error message: [DCC Error] VCLTee.TeCanvas.pas(5588): E2010 Incompatible types: 'TeCanvas.TTeeCanvas' and 'VCLTee.TeCanvas.TTeeCanvas'
Post by Yeray » Mon May 30, 2016 8:26 am
Hello Bruce,
Sounds as a problem with the prefixes. Have you tried adding "VCLTee" to the "unit scope names"?
BruceC
Post by BruceC » Wed Jun 01, 2016 4:21 am
I was still using XE2 for just a couple of legacy projects that were using components that I do not have the source for and are now no longer available.
I decided to use other components instead and am now using 10.1 Berlin so the problem has gone away.
Thanks for your help.
Bruce
