Animations with label and percent error
Posted: Thu Jun 02, 2016 2:27 pm
by 16478259
I bought the TeeChart pro version for delphi 7. When I want to animate a pie chart with label and percent values showing each portion are erroneous. The same applies to bar series, however if the sample values show well. See the attachment!
I would also like to know the version I sign says "TRIAL" if I have com meadow (TeeChart Pro v2015.14.150120 trial)?
And every time when modify a chart show error message "property detail not found"
Re: Animations with label and percent error
Posted: Thu Jun 02, 2016 2:52 pm
I've tried to reproduce the problem with this code but it seems to give me a correct percentage in the legend:
uses Series, TeeDonut;
  with Chart1.AddSeries(TDonutSeries) as TDonutSeries do
    AddPie(2185.85, 'Promotores');
    AddPie(1236.47, 'Pasivos');
    AddPie(662.83, 'Detractores');
  Chart1.Legend.TextStyle:=ltsRightPercent;
jars wrote:I would also like to know the version I sign says "TRIAL" if I have com meadow (TeeChart Pro v2015.14.150120 trial)?
If you mean in the aboutbox, this is a known issue we corrected in further releases.
jars wrote:And every time when modify a chart show error message "property detail not found"
Posted: Fri Jun 03, 2016 4:06 pm
by 16478259
Hi Yeray.
In the ErrorExample.zip attachment is the example that show after play animate button, labels percent always show 100%
In the ErrorImages.zip attachment are printscreens with the errors that was commented.
Jorge
Posted: Mon Jun 06, 2016 8:42 am
Thanks to your test application I could reproduce the problem with TeeChart v2015.14. I could also reproduce the problem with v2015.15.
However, it seems to work fine from 2015.16 and up. So I'd suggest you to update to the latest version available, v2016.18.
Posted: Mon Jun 06, 2016 6:48 pm
by 16478259
This version 2016.18 is valid for Delphi 7? It not appears as option?
Posted: Tue Jun 07, 2016 7:10 am
From the v2016.18 TeeChart supports Delphi 7 only in the source code version. You'll find it in the "legacy" group.
