user_bme
Post
by user_bme » Thu Jun 30, 2016 12:55 pm
When I export data of my application from TDbChart componenet to Excel, export appears like:
I need:
Replace the text in the first column "Text" for "Value"
Hide / Remove the "X" column
How can I do it?
PD:
Version TeeChar Pro v2015.26.150901 32 bit VCL
Attached example of my code
procedure TFGestionCurvasCalculadas.actExportExecute(Sender: TObject);
var tmpChart: TChart;
i : Integer;
tmpChart := TChart.Create(Self);
try
for i := 0 to dbcCurves.SeriesCount - 1 do
if dbcCurves[i].Active then
CloneChartSeries(dbcCurves.Series[i]).ParentChart := tmpChart;
tmpChart.SeriesList[i].XValues.DateTime := True;
tmpChart.SeriesList[i].YValues.Name := 'Curve';
with TSeriesDataXLS.Create(tmpChart, nil) do
try
UseSeriesFormat := True;
IncludeHeader := True;
SaveToFile('C:\TEMP\example.xls');
finally
Free;
finally
tmpChart.Free;
Post
by Yeray » Fri Jul 01, 2016 4:14 pm
You could do something like this:
uses TeeStore, TeeConst;
type TSeriesAccess=class(TChartSeries);
TeeMsg_Text:='Value';
TSeriesAccess(Series1).IUseNotMandatory:=false;
with TSeriesDataXLS.Create(Chart1, nil) do
try
SaveToFile('E:\tmp\example.xls');
finally
Free;
user_bme
Post
by user_bme » Mon Jul 04, 2016 8:51 am
First of all, thanks for your help.
I've already got the "x" column does not appear.
The problem is the caption "Text", I need to change it to "Value".
In the example that you sent me, the variable "TeeMsg_Text" appears, but do you not use it anywhere. I think you let use to show me how to change the text.
I wait your answer.
Thank you very much.
user_bme
Post
by user_bme » Mon Jul 04, 2016 9:26 am
Work's.
I need to use Teeconst.
Thank you.
