Adding a TColorBandTool, resizing immediately
Test Always
Post by Test Always » Mon Sep 19, 2016 11:13 pm
I am adding a band to a chart as soon as the user clicks on the chart--and I want to start resizing the band as soon as it is added. Can that be done?
Ed Dressel
Re: Adding a TColorBandTool, resizing immediately
Post by Yeray » Tue Sep 20, 2016 8:01 am
Hello Ed,
Yes, you can use the mouse events to do so.
I'm not sure how do you want to determine what TColorLineTool (StartLine/EndLine) should be dragged (note dragging one of the two TColorLineTools in the TColorBandTool is a TColorBandTool resizing) when you just created the tool.
Here you have an example that creates the TColorBandTool and starts dragging it at OnMouseDown event:
uses Series, TeeTools;
type TMyColorBandTool=class(TColorBandTool)
  private
    Dragging : Boolean;
    Old      : Double;
var myColorBand: TMyColorBandTool;
  Chart1.View3D:=false;
  Chart1.AddSeries(TBarSeries).FillSampleValues();
  if not Assigned(myColorBand) then
    myColorBand:=Chart1.Tools.Add(TMyColorBandTool) as TMyColorBandTool;
    with myColorBand do
      Axis:=Chart1.Axes.Bottom;
      StartValue:=2;
      EndValue:=4;
      if not ParentChart.CancelMouse then
        Dragging:=True;
        if Axis.Horizontal then
           Old:=Axis.CalcPosPoint(X)-StartValue
           Old:=Axis.CalcPosPoint(Y)-StartValue;
        ParentChart.CancelMouse:=True;
  Y: Integer);
var tmpValue,
    tmpStartValue,
    tmpDiff  : Double;
  if Assigned(myColorBand) and myColorBand.Dragging then
    with myColorBand do
      tmpDiff:=EndValue-StartValue;
         tmpValue:=Axis.CalcPosPoint(X)-Old
         tmpValue:=Axis.CalcPosPoint(Y)-Old;
      if NoLimitDrag then
         tmpStartValue:=tmpValue
         tmpStartValue:=StartLine.LimitValue(tmpValue);
      tmpValue:=EndLine.LimitValue(tmpStartValue+tmpDiff);
      if (not NoLimitDrag) and (tmpValue<(tmpStartValue+tmpDiff)) then
         StartValue:=tmpValue-tmpDiff
         StartValue:=tmpStartValue;
      EndValue:=StartValue+tmpDiff;
procedure TForm1.Chart1MouseUp(Sender: TObject; Button: TMouseButton;
  if Assigned(myColorBand) then
     myColorBand.Dragging:=False;
