TQRChart Package Installation
TimH
Post by TimH » Sat Sep 24, 2016 11:33 am
Delphi Seattle 10 Enterprise
QuickReport 6 Pro
Steema TeeChart Pro 2012/16 latest version
I have downloaded and followed the instructions to Build and Compile the Design Time and Runtime bpl's and copied to relevant directories.
I then try and ad the TQRChart design time package to Delphi's package list and get the following error :-
Cannot load package DCLTee923. It contains unit VCLTee.TeechartExp which is also contained in package DCLTeePro923
Any assistance would be appreciated
Re: TQRChart Package Installation
Post by Yeray » Mon Sep 26, 2016 9:30 am
Find attached the TQRChart packages precompiled for TeeChart Pro v2016.18, QuickReport v6 and RAD Studio 10 Seattle:
Tee9QR6D23.zip
(130 KiB) Downloaded 615 times
The compiledwin32 and compiledwin64 folders contain the packages you should be able to use without having to recompile the packages. To use them just copy the packages from the "compiledwin32" folder accordingly:
- DclTee9QR6D23.bpl to $(BDS)\bin
- Tee9QR6D23.bpl to %windir%\SysWOW64 (if you are in a 64bit OS) or to %windir%\System32 (if you are in a 32bit OS)
- The rest of the files from the "compiledwin32" folder to $(BDS)\lib\win32\release and $(BDS)\lib\win32\Debug
In the case you want compile you projects for Win64, also copy the packages from the "compiledwin64" folder accordingly:
- Tee9QR6D23.bpl to %windir%\System32.
- The rest of the files from the "compiledwin64" folder to $(BDS)\lib\win64\release and $(BDS)\lib\win64\Debug
Then you should be able to open the IDE, add the $(BDS)\bin\DclTee9QR6D23.bpl package to the components list in the IDE and use it.
TimH
Post by TimH » Mon Sep 26, 2016 11:00 am
Thanks - Worked a Treat.
Could you also post for Berlin 10.1 and QuickReport 6 as I have another instance using Berlin and not Seatle which I'm also battling to get working
Thanks for your assistance
Tim
Post by Yeray » Mon Sep 26, 2016 11:04 am
Hi Tim,
TimH wrote:Could you also post for Berlin 10.1 and QuickReport 6 as I have another instance using Berlin and not Seatle which I'm also battling to get working
They are here:
http://www.teechart.net/support/viewtop ... D24#p72140
TimH
Post by TimH » Fri Oct 07, 2016 9:48 am
Followed instructions for the Berlin 10.1 installation and have the run into the following -
1. Complained about compiled in a different version so built and compiled both Dcl and Tee with no issues.
2. Copied all the files as per instructions to the relevant directories
3. Went to Component and added the Dcl package from the Delphi Bin location as instructed but got the following error :-
Can't load package C:\Program Files (x86)\Embarcadero\18.0\bin\DclTee9QR6D24.bpl. The specified module could not be found
I have tried a number of times from scratch using your supplied files - but still get this - the package is there as I am choosing it so a bit confused as it is there ?
Any help would be appreciated
Tim
Post by Yeray » Fri Oct 07, 2016 10:35 am
TimH
Post by TimH » Fri Oct 07, 2016 10:42 am
All fixed - was being stupid :(
Tim
