JRadke
Post
by JRadke » Thu Jan 12, 2017 9:36 am
I have assigned a TColorBandTool to the bottom axis of a chart and want to change the text position of the StartLine to the left-top corner.
I've tried the following code:
with MyColorBandTool do begin
StartLine.Annotation.Text := 'My text';
StartLine.Annotation.Position := ppLeftTop;
but the text is always positioned at the middle of the axis.
Is there a way to chance it?
Kind Regards
Juergen
Post
by Yeray » Fri Jan 13, 2017 10:39 am
Hello Juergen,
The
TColorBandTool embeds two
TColorLineTools, and the
TColorLineTool embeds a
TAnnotationTool. However, the
Position property is designed to be used with the
TAnnotationTool alone. In these embedded
TAnnotationTools the chart calculates the position automatically.
If you want further customization, you should hide the embedded annotation, create an independent
TAnnotationTool and reposition it at the
TColorBandTool OnChanged event. Ie:
var MyColorBand: TColorBandTool;
MyStartAnnotation: TAnnotationTool;
Chart1.View3D:=False;
Chart1.Legend.Visible:=False;
Chart1.AddSeries(TLineSeries).FillSampleValues;
MyColorBand:=Chart1.Tools.Add(TColorBandTool) as TColorBandTool;
with MyColorBand do
Axis:=Chart1.Axes.Bottom;
StartValue:=15;
EndValue:=20;
OnChanged:=ColorBandChange;
MyStartAnnotation:=Chart1.Tools.Add(TAnnotationTool) as TAnnotationTool;
MyStartAnnotation.Text:='My text';
Chart1.Draw;
ColorBandChange(MyColorBand);
procedure TForm1.ColorBandChange(Sender: TObject);
MyStartAnnotation.Shape.Left:=MyColorBand.Axis.CalcPosValue(MyColorBand.StartLine.Value);
MyStartAnnotation.Shape.Top:=Chart1.ChartRect.Top;
JRadke
Post
by JRadke » Fri Jan 13, 2017 12:54 pm
Hello Yeray,
Thank you for your reply.
I will take your example code as template for my further work.
Kind regards
Juergen
