TeeRecompile (20017.21) wants to compile for C++
Stephane
Post by Stephane » Tue May 02, 2017 5:36 pm
I just downloaded the latest version in order to port my application to Delphi 10.2 Tokyo but when I attempt to run Teerecompile, it confuses the IDE and thinks I'm using CBuilder instead of Delphi, only for Tokyo (XE5 and 10.1 Berlin).
As a result, I am unable to use that new version and IDE.
Re: TeeRecompile (20017.21) wants to compile for C++
Post by Yeray » Thu May 04, 2017 8:21 am
Could you please tell us what exact error message does TeeRecompile show?
MrI
Post by MrI » Wed May 10, 2017 2:56 am
I have the same problem, I think.
I can only see C++ but I need Delphi.
Here is an image.
Post by Yeray » Wed May 10, 2017 11:11 am
That "C++" doesn't mean only CBuilder personality is detected.
Do you get any error when you select RX10.1 Berlin and press "BEGIN"?
MrI
Post by MrI » Thu May 11, 2017 12:13 am
A few errors.
Two errors looking like this and I cant read or click that link. This is most likely not the problem.
The third error looks like this and looks to be closer related to what you describe. dccosx.exe cannot be found. This Delphi personality is missing here.
Post by Yeray » Thu May 11, 2017 7:57 am
The first message is a warning, not an error. The problem of the url clipped has been fixed for the next maintenance release. The complete link is:
https://community.embarcadero.com/artic ... builder-10
Can you paste here the text from the "Log" tab after failing to recompile?
I guess you've ran TeeRecompile with "Mac OSX" checkbox active. If you don't want to use that, you can try unselecting it and running TeeRecompile again.
MrI
Post by MrI » Thu May 11, 2017 8:08 am
TeeChart Pro
Compilation started: 2017-05-11 17:04:02
Win32 v24 (Delphi 10.1 Berlin and C++Builder 10.1 Berlin Update 2) (C++)
Tee924
Embarcadero Delphi for Win32 compiler version 31.0
Copyright (c) 1983,2016 Embarcadero Technologies, Inc.
93596 lines, 1.17 seconds, 980396 bytes code, 4836 bytes data.
TeeUI924
88245 lines, 1.56 seconds, 635188 bytes code, 1420 bytes data.
TeeDB924
9464 lines, 0.45 seconds, 87588 bytes code, 308 bytes data.
TeePro924
VCLTee.TeeSurfa.pas(6546) Hint: H2077 Value assigned to 'tmpIndex' never used
243830 lines, 4.96 seconds, 1398068 bytes code, 64212 bytes data.
TeeGL924
16797 lines, 0.44 seconds, 137404 bytes code, 3184 bytes data.
TeeImage924
28158 lines, 0.56 seconds, 330792 bytes code, 11604 bytes data.
TeeWorld924
5314 lines, 0.45 seconds, 51444 bytes code, 1080 bytes data.
TeeLanguage924
90723 lines, 0.84 seconds, 3568000 bytes code, 3672 bytes data.
TeeImport924
6232 lines, 5.21 seconds, 70128 bytes code, 244 bytes data.
DclTee924
8940 lines, 2.57 seconds, 141044 bytes code, 360 bytes data.
DclTeePro924
5442 lines, 0.98 seconds, 188208 bytes code, 476 bytes data.
DclTeeProStd924
11755 lines, 1.00 seconds, 168168 bytes code, 464 bytes data.
TeeMaker124
92556 lines, 1.68 seconds, 827564 bytes code, 12776 bytes data.
DclTeeMaker124
1039 lines, 1.51 seconds, 20564 bytes code, 224 bytes data.
FMXTee924
87564 lines, 2.25 seconds, 919796 bytes code, 4364 bytes data.
FMXTeeUI924
73733 lines, 1.92 seconds, 543128 bytes code, 1128 bytes data.
FMXTeeDB924
9482 lines, 0.58 seconds, 91624 bytes code, 308 bytes data.
FMXTeePro924
FMXTee.Series.Surface.pas(6547) Hint: H2077 Value assigned to 'tmpIndex' never used
192844 lines, 3.62 seconds, 1409216 bytes code, 64608 bytes data.
FMXTeeLanguage924
90764 lines, 1.90 seconds, 3569200 bytes code, 3672 bytes data.
FMXTeeImport924
6123 lines, 0.78 seconds, 75524 bytes code, 236 bytes data.
DclFMXTee924
4901 lines, 0.84 seconds, 111020 bytes code, 288 bytes data.
DclFMXTeePro924
2157 lines, 1.12 seconds, 135228 bytes code, 308 bytes data.
16447 lines, 3.40 seconds, 216706 bytes code, 372 bytes data.
DclFMXTeeProStd924
5871 lines, 1.14 seconds, 118836 bytes code, 304 bytes data.
Compilation started: 2017-05-11 17:05:28
TeeTree2D24Tee9
49794 lines, 0.78 seconds, 626604 bytes code, 1520 bytes data.
FMXTree24
16489 lines, 0.48 seconds, 201408 bytes code, 388 bytes data.
DclTree2D24Tee9
1735 lines, 0.41 seconds, 16392 bytes code, 260 bytes data.
DclFMXTree24
740 lines, 0.44 seconds, 11784 bytes code, 208 bytes data.
TeeChart Installation
  VERSION:  2017
Installing...
Win32 v24 (Delphi 10.1 Berlin and C++Builder 10.1 Berlin Update 2) (C++) OK. Time:  1m  29s
Win64 v24 (Delphi 10.1 Berlin and C++Builder 10.1 Berlin Update 2) (C++)
EXCEPTION:
Operation aborted
MrI
Post by MrI » Thu May 11, 2017 8:19 am
I reinstalled Berlin and posted the log earlier for you. Something changed. Now I can see "Delphi", but the same error.
Post by Yeray » Thu May 11, 2017 1:41 pm
An error trying to find the Mac OSX compiler, dccosx.exe, when compiling the packages for Win64 sounds really strange.
Even if I it shouldn't be necessary for a Win64 compilation, could you please check if the exe is in the specified folder?
MrI
Post by MrI » Fri May 12, 2017 1:54 am
I reinstalled Delph again and now the TeeRecompiler could install and only showing the SDK error.
Turns out that you should have 64-bit Delphi installed if you want the Win64 TeeChart. You get strange errors otherwise. My bad.
Still it doesn't explain why I got the error before, before I reinstalled both 32 and 64. When Berlin Rad studio was installed, Delphi and C++. v10.1 without Update 2.
But the installation was successful, I'm happy with that.
Post by Yeray » Fri May 12, 2017 7:02 am
Maybe the problem was the Update 2. Note we always recommend our customers to keep their IDEs up to date.
One way or another, I'm glad to hear it works now for you! :D
