TeeChart gradient in a DLL
LucaC
Post by LucaC » Thu May 11, 2017 7:36 am
I've some TChart into a Delphi dll.
I've made a porting of one of my dll modules that uses TeeChart. The version is 2016.19.
I've the same module running without problem in XE2 environment with TeeChart 2012.
How can i use gradient fill in new version of TChart/Delphi? Tha backgroung is always gray. Only Color property affect the background gradient don't work.
Thank you
Re: TeeChart gradient in a DLL
Post by Yeray » Thu May 11, 2017 10:24 am
If I drop a TChart into a new Form and I put this code at OnCreate:
  Chart1.Gradient.StartColor:=clWhite;
  Chart1.Gradient.EndColor:=clDkGray;
  Chart1.Gradient.MidColor:=clNone;
  Chart1.Walls.Back.Gradient.StartColor:=clDkGray;
  Chart1.Walls.Back.Gradient.EndColor:=clWhite;
I get this with the current TeeChart v2017.21:
So the gradients seem to work fine for me here with the latest version.
LucaC
Post by LucaC » Thu May 11, 2017 12:26 pm
Ok, also if I put the chart into a VCL Form Application all is Working correctly.
My problem is if I put the Chart on a Form that reside into a DLL.
Post by Yeray » Fri May 12, 2017 7:51 am
There may be some extra properties to set. Ie:
  Chart1.Gradient.Visible:=True;
  Chart1.Walls.Back.Transparent:=False;
See the test project:
TeeChart_GDIPlus_exe_and_dll_gradients.zip
(57.66 KiB) Downloaded 580 times
