EOutOfMemory with TSurfaceSeries
Uwe Raabe
Post by Uwe Raabe » Sun May 21, 2017 10:13 am
I get an EOutOfMemory exception displaying a 3D surface with my data. Luckily I was able to track down the problem to a few lines of code:
  • create a VCL forms application
  • drop a TChart onto the form
  • add a 3D surface series
  • execute the code below
var
  I: Integer;
  J: Integer;
  Series1.Clear;
  for I := 10 to 100 do begin
    for J := 1 to 100 do begin
      Series1.AddXYZ(I*10, Random(10), J*100000);
The problem seems to be related to the large X- and Z-values. Everything is OK when the factor is removed.
Re: EOutOfMemory with TSurfaceSeries
Post by Sandra » Mon May 22, 2017 2:21 pm
Hello Uwe,
The problem is caused because the data values you add in your series are irregular. Therefore you need setting the surface's to IrregularGrid=true as do in code below:
procedure TForm3.FormCreate(Sender: TObject);
var
  I: Integer;
  J: Integer;
  Series1.Clear;
  Series1.IrregularGrid := true;
end.
Notice that such series need to be populated as described here.
Hoping this helps you.
Thanks in advance
