Bar chart export to DXF
johnnix
Post by johnnix » Fri May 26, 2017 6:14 am
Is it possible to export a bar chart to DXF and retain the fill?
Re: Bar chart export to DXF
Post by Sandra » Fri May 26, 2017 3:41 pm
Hello johnnix,
I'm afraid Teechart Pro VCL/FMX doesn't support export to DXF format. May be useful for you, use Native Template format (tee) to achieve you want.
Also, I would suggest you take a look in our Teechart VCL Feature Matrix, specifically to check the Export formats Teechart supports.
Thanks in advance
Regards!
