Problem with Marks not always showing
weatherdisplay
Post by weatherdisplay » Fri Jun 02, 2017 11:01 pm
HI
This bug was introduced in a recent update of Tchart
The value for a point, as shown as the Mark, does not always get displayed, like it used to
I have a test project to illustrate:
http://www.weather-display.com/download ... ject74.zip
change the spinedit by say 1 up or down and click on test..the word test will show at the top of the line for 1 value and then not for another value for the spinedit
this used to work for any value but now its like only every 4 values change
thanks for any help
Brian
weatherdisplay
Re: Problem with Marks not always showing
Post by weatherdisplay » Mon Jun 05, 2017 11:04 pm
I have filed a bug report
http://bugs.teechart.net/show_bug.cgi?id=1876
thanks in advance
Post by Yeray » Thu Jun 08, 2017 11:28 am
Hello Brian,
weatherdisplay wrote:This bug was introduced in a recent update of Tchart
I see it could have been introduced in v2016.19.
I've confirmed the #1876 ticket and added a simplified test project to it.
weatherdisplay
Post by weatherdisplay » Fri Jun 09, 2017 1:19 am
Hi
any chance you can make available that older version v2016.19 to be compatible with Delphi Berlin?
thanks
Post by Yeray » Fri Jun 09, 2017 6:36 am
weatherdisplay wrote:any chance you can make available that older version v2016.19 to be compatible with Delphi Berlin?
Berlin is supported since v2016.17, so v2016.19 should work with it.
Note the bug was introduced in v2016.19, so you should move to a previous version, ie v2016.18.
weatherdisplay
Post by weatherdisplay » Fri Jun 09, 2017 7:54 pm
good oh
I had not tried going back that far
trying now
will let you know
weatherdisplay
Post by weatherdisplay » Fri Jun 09, 2017 8:30 pm
sucsess :)
also much easier to install that older version, as much smaller install file sizes (why such a big jump after this version?)
Post by Yeray » Mon Jun 12, 2017 6:48 am
weatherdisplay wrote:sucsess :)
Great!
weatherdisplay wrote:also much easier to install that older version, as much smaller install file sizes (why such a big jump after this version?)
Do you mean in the installer itself or in the resultant installation?
I see the TeeWorldSeries received many modifications in v2016.19 and, since there are 7 platforms supported with in Berlin (win32, win64, osx32, android, iosdevice, iosdevice64 and iossimulator), all the related dcus and packages increased a bit in size.
