TTextblock Class Conflict
nader
Post by nader » Tue Jun 27, 2017 3:31 pm
Setting up TeeChart for Delphi 10.2 was failing on my workstation due to a conflict in TTextblock class, it seems there is a class with similar name in TMS Diagram Package, can you add a prefix to your class? I have also contacted TMS.
Nader
Re: TTextblock Class Conflict
Post by Yeray » Fri Jun 30, 2017 9:53 am
I see this is defined in TeeBlocks. Are you using TeeMaker/Chart3D?
We'll try to add the VCLTee/FMXTee prefix to it, as usually.
wvisser
Post by wvisser » Mon Sep 18, 2017 9:06 am
When will the TTextblock class prefix be added? Or has it already been added?
Is it easy to do it yourself in the code?
regards, Wilfried
Post by Yeray » Wed Sep 20, 2017 1:59 pm
Hello Wilfried,
We've added the unit name (TeeBlocks) to every TTextBlock reference in TeeMaker/Chart3D sources to avoid this class conflict.
Ie, this code:
    result:=TTextBlock.Create(IOwner);
Is now this:
    result:=TeeBlocks.TTextBlock.Create(IOwner);
