Problem with bar series (THorizBarSeries)
Alexandre
Post by Alexandre » Thu Oct 05, 2017 5:34 pm
For bar series, the functions "AddXY" and "AddNullXY" do not insert, internally, the points in same order that column series. There is a sample attached.
I think that this is a BUG. Can anyone help me?
Thank you.
Alexandre da Silva.
Unit1.rar
(2.11 KiB) Downloaded 587 times
Re: Problem with bar series (THorizBarSeries)
Post by Yeray » Fri Oct 06, 2017 1:26 pm
Sorting the values in your series helps on the majority of cases. However, note you should also have the same number of values in both series when using stacked.
Here a method you can call after adding your values that solves that problems:
procedure TForm1.FillAndSort;
    procedure Sync(ASeries1, ASeries2: TChartSeries);
    var i, j: Integer;
        exists: Boolean;
      for i:=0 to ASeries1.Count-1 do
        exists:=False;
        for j:=0 to ASeries2.Count-1 do
          if ASeries1.NotMandatoryValueList[i] = ASeries2.NotMandatoryValueList[j] then
            exists:=True;
            break;
        if not exists then
          if ASeries1 is THorizBarSeries then
             ASeries2.AddNullXY(0, ASeries1.YValue[i])
             ASeries2.AddNullXY(ASeries1.XValue[i], 0);
  Sync(Chart1[0], Chart1[1]);
  Sync(Chart1[1], Chart1[0]);
  Sync(Chart2[0], Chart2[1]);
  Sync(Chart2[1], Chart2[0]);
  Chart1[0].XValues.Sort;
  Chart1[1].XValues.Sort;
  Chart2[0].YValues.Sort;
  Chart2[1].YValues.Sort;
