Cannot compile D2007
Nickm
Post by Nickm » Fri Nov 03, 2017 9:15 am
I needed to upgrade to get a fix (Excel export with later versions of Office)
I have just downloaded the latest version of V2017.22 (with full source) and tried to install on Delphi 2007 but when using TEECompile I get the following error:
TeeChart Pro
Compilation started: 02/11/2017 15:08:12
Win32 v11 Enterprise (December 2007 Update)
Tee911
Cannot recompile Delphi package: Tee911.dpk CodeGear Delphi for Win32 compiler version 18.5 Copyright (c) 1983,2007 CodeGear
TeeProcs.pas(8158) Warning: W1000 Symbol 'GetHeapStatus' is deprecated
Series.pas(10926) Error: E2018 Record, object or class type required
Tee911.dpk(55) Fatal: F2063 Could not compile used unit 'Series.pas'
EXCEPTION:
Compilation aborted.
Re: Cannot compile D2007
Post by Yeray » Fri Nov 03, 2017 9:29 am
Nickm wrote:Series.pas(10926) Error: E2018 Record, object or class type required
If I'm not wrong, this is the line of the error, line 10926 of Series.pas:
  TPenAccess(Pen).InitEndStyle({$IFDEF D9}TPenEndStyle.{$ENDIF}esFlat);
Try modifying that line for this:
  TPenAccess(Pen).InitEndStyle({$IFDEF D16}TPenEndStyle.{$ENDIF}esFlat);
Nickm
Post by Nickm » Fri Nov 03, 2017 2:23 pm
Thanks - that's fixed it.
