Access violation with TeeChart, Fast Reports with C++Builder
Posted: Mon Mar 19, 2018 12:52 pm
by 16481994
I’m getting an error when target platform is set to Win64 (VCL or FMX) and using a TeeChart in a Fast Reports report.
Fast Reports thinks the problem is in TeeChart.
To get the access violation the chart needs to have some data in it.
Error Message:
Access violation at address 45B70B in module ‘rtl250.bpl’. Read of address 8E.
Tried: Windows 7 & 10
CX: 10.2.3
CX: 10.2.2
TeeChart Pro v2017.23.171221
Fast Reports: VCL: v5.6.11; FMX: v2.5.11
Re: Access violation with TeeChart, Fast Reports with C++Builder
Posted: Wed Mar 21, 2018 11:38 am
by 16481994
Don’t install “TeeChartVCLFMX-2017.23.exe” if your using Fast Reports with x64.
Had to go back to CX 10.2.0 & TeeChartVCLFMX-2017.22.exe.
Posted: Fri Mar 23, 2018 11:25 am
I can build "FastReport 6.0 Tee Components" and "FastScript 1.9 Tee Components" using the recompile.exe tool shipped with Fast Reports 6 Trial version for both win32 and win64.
- recompile_2018-03-23_12-21-20.png (17.07 KiB) Viewed 13392 times
- recompile_2018-03-23_12-20-59.png (17.92 KiB) Viewed 13390 times
Then I could drop a TfrxChartObject to a Form in a VCL project, and it compiles without problems in both win32 and win64.
Am I missing anything?
Posted: Fri Mar 23, 2018 2:30 pm
by 16481994
The Fast Reports build works fine for win32 and win64.
It’s running a program with the TfrxChartObject in it that doesn’t not work in win64.
I sent a test case for you. Run it you’ll see.
Posted: Mon Mar 26, 2018 9:23 am
I've been able to run the test application without problems. I just had to copy the fs25.bpl, frx25.bpl, fsTee25.bpl and frxTee25.bpl files, from LibD25 to SysWOW64 and from LibD25x64 to System32 folders.
- Project1_2018-03-26_11-18-08.png (22.69 KiB) Viewed 13364 times
Posted: Mon Mar 26, 2018 3:24 pm
by 16481994
Yeray,
Thanks for working out this Fast Reports problem.
Alan
