Delphi Rio Install Issues
dblount
Post by dblount » Fri Feb 15, 2019 12:15 pm
Downloaded TeeChartVCLFMX-2018.26.exe and installed in a folder on C: drive dedicated to Delphi components, no errors were shown through-out the install process.
After launching Delphi again, and opening a project, TChart does not appear in the component palette, also I can't find TeeRecompile.exe on my machine.
Any ideas?
Re: Delphi Rio Install Issues
Post by Yeray » Mon Feb 18, 2019 11:12 am
First note TeeRecompile.exe is only included with the source code installer (TeeChartVCLFMXSOURCE-2018.26.exe); the binary installer (TeeChartVCLFMX-2018.26.exe) includes TeeInstall.exe.
It may be related with permissions. Could you please try running the installer "as administrator"?
An alternative would be to install in the default folder, and if everything goes fine, move the installation to the folder of your choice.
dblount
Post by dblount » Mon Feb 18, 2019 12:34 pm
Where can I located (TeeChartVCLFMXSOURCE-2018.26.exe), can't find it here: https://www.steema.com/ma_registered_versions.
Post by Yeray » Tue Feb 19, 2019 11:20 am
Do you have an active source code license? Please check it with sales department at "sales at steema dot com".
