Fill area between 2 series
Posted: Mon Apr 08, 2019 9:04 am
by 16584466
I believe this question was asked many years ago but I could not retrieve anything from Search.
I need to fill the area between 2 series (e.g. Series1 and Series2) with a constraint that fill will apply only when Series1 values are smaller than Series 2 (see attached image), I tried using the available TChart tools but with no luck, any help would be mostly appreciated
Re: Fill area between 2 series
Posted: Mon Apr 08, 2019 11:25 am
Check the Series Band Tool. I've just run the "All features\Welcome !\Tools\Series Band" example in the New Features demo, changed the series from Line series to HorizLine series and reassigned the second series for the tool:
- Tee9new_2019-04-08_13-23-26.png (177.39 KiB) Viewed 20456 times
Posted: Mon Apr 08, 2019 12:35 pm
by 16584466
I tried that, had to change both line series to Horizontal type however the result is not good.
Posted: Tue Apr 09, 2019 8:24 am
Please, arrange a simple example project we can run as-is to reproduce the problem here.
Posted: Tue Apr 09, 2019 2:33 pm
by 16584466
Here is a sample app
Posted: Thu Apr 11, 2019 11:27 am
I could reproduce the problem so I've added it tot he public tracker:
#2182.
Note I've already fixed it.
The fix consists on modifying the TryAddCrossPoint function in TeeSeriesBandTool.pas, from this:
function TryAddCrossPoint(t:Integer; isStairs,isStairs2:Boolean):Boolean;
if result then
AddPointXY(Series.CalcXPosValue(X),Series.CalcYPosValue(Y))
end
if IsStairs then
AddPoint(Series,IsStairs,t);
To this:
if result then
if Series.YMandatory then
AddPointXY(Series.CalcXPosValue(Y),Series.CalcYPosValue(X));
end
if IsStairs then
Posted: Thu Apr 11, 2019 1:10 pm
by 16584466
Thank you, will give it a try
