Function Declarations
Jennifer
Post by Jennifer » Tue Jan 04, 2005 1:11 am
We are using Teechart VI and Delphi V and have a problem using functions. we made a simple example[below]. What happens is that
when we compile, the compiler says the calcuilate method cannot be found.
Jennifer
unit Unit1;
interface
uses
Windows, Messages, SysUtils, Classes, Graphics, Controls, Forms,
Dialogs,TeEngine, Series, ExtCtrls, TeeProcs, Chart;
type
Tderivfunction=Class(TTeefunction);
TForm1 = class(TForm)
Chart1: TChart;
Series1: TFastLineSeries;
procedure FormActivate(Sender: TObject);
private
{ Private declarations }
public
Form1: TForm1;
Function Tderivfunction.calculate(SourceSeries:TchartSeries;
first,last:Longint):Double;
implementation
{$R *.DFM}
VAR
kk:Integer;
startpoint,endpoint:LongInt;
BEGIN
IF First <>-1 Then startpoint:=first;
IF Last <>-1 Then endpoint:=Last;
FOR kk:=startpoint to endpoint Do
result:=sourceseries.getYvalue(kk+1)-
sourceseries.getYvalue(kk-1);
END;
procedure TForm1.FormActivate(Sender: TObject);
end.
Marjan
Post by Marjan » Tue Jan 04, 2005 9:15 am
Hi.
That's true, because you haven't declared the Calculate method in TDerivFunction interface. Slightly different code is needed when you derive new class from existing class:
  TDerivFunction=Class(TTeefunction)
  public
    Function Calculate(SourceSeries:TChartSeries; FirstIndex,LastIndex:Integer):Double; override;
function TDerivFunction.Calculate(SourceSeries: TChartSeries; FirstIndex,
  LastIndex: Integer): Double;
var kk:Integer;
    startpoint,endpoint: Integer;
  // Your implementation goes here
But if you're calculating series 1st derivative, why don't you rather override the TTeeFunction.AddPoints method ? The following example should calculate series 1st derivative using simple forward difference formula:
  public
    procedure AddPoints(Source:TChartSeries); override;
procedure TDerivFunction.AddPoints(Source: TChartSeries);
var dy,dx,doty: Double;
    t: Integer;
  ParentSeries.Clear;
  for t:=0 to Source.Count-2 do
    dx := Source.NotMandatoryValueList[t+1]-Source.NotMandatoryValueList[t];
    dy := Source.MandatoryValueList[t+1]-Source.MandatoryValueList[t];
    if dx <> 0.0 then
      doty := dy/dx;
      ParentSeries.AddXY(Source.NotMandatoryValueList[t],doty);
Of course, you can use more elaborate and complex approximations, but the basic idea is the same.
Marjan Slatinek,
Jennifer
function declaration
Post by Jennifer » Tue Jan 04, 2005 3:31 pm
Thanks very much-Sometimes I wonder how we can be so obtuse aropund here. Probably form practice:-)
Jennifer
Marjan
Post by Marjan » Wed Jan 05, 2005 8:17 am
:lol:
Been there, done that :P
Marjan Slatinek,
