Creating a Bar Chart limited to a Single Record
Posted: Wed Jul 29, 2020 8:32 pm
by 16487010
How can I limit a stacked bar chart to a single record from a query? I need to be able to have the chart appear to the user in a ReportBuilder Report based on current record. I have done this for 15 years or so in FastReports, but need to move beyond them for other reasons.
Re: Creating a Bar Chart limited to a Single Record
Posted: Thu Jul 30, 2020 8:44 am
The easiest way I can think to do this is by setting the bottom axis to just show the last value. Ie:
with Chart1[0] do
diff:=(XValues.Last-XValues[Count-2]) / 2;
Chart1.Axes.Bottom.SetMinMax(XValues.Last-diff, XValues.Last+diff);
Posted: Thu Jul 30, 2020 12:47 pm
by 16487010
Maybe I need to provide more detail. I have a series of records in a table that has three values I want to place in a stacked bar chart - Total Budget, Current Invoice, and Previous Invoices. As the report generator steps through the table, it needs to provide a chart based on the three fields in that particular record. Right now the bar chart provides separate stacked bars for the entire table all at once.
Posted: Thu Jul 30, 2020 6:48 pm
by 16487010
I solved the problem by setting up a FDMemTable to provide data to the chart. As my Query steps through it's data, it triggers an OnDataChange event. I use this event to empty the MemTable and then copy the values I need from the Query to the MemTable. It works perfectly.
Posted: Fri Jul 31, 2020 6:24 am
I may be missing something else because I still think the same code applies here.
Here a simple example showing three stacked bars with several values:
i: Integer;
const
titles: array[0..2] of string = ('Total Budget', 'Current Invoice', 'Previous Invoices');
for i:=0 to 2 do
Title:=titles[i];
FillSampleValues;
MultiBar:=mbStacked;
Marks.Hide;
Chart1.Legend.Alignment:=laBottom;
- all.png (7.41 KiB) Viewed 14949 times
Here the same chart after calling that code to only show the last bar:
- last.png (8.66 KiB) Viewed 14949 times
