Caption goes outside of bounderies
In a very simple demo (attached) I have a caption on the left axis (but this problem can occur on other axes as well) where the caption can go beyond the area it should if the app is made smaller--here is an image from the attached demo where I resized the app and the left axis caption goes outside of the area:
Is there a way to do word warp on the captions automatically? How can I make it so the caption always shows up?
Thank you,
Ed Dressel
Thank you,
Ed Dressel
- Axis Caption.zip
- (1.67 KiB) Downloaded 754 times
Ed Dressel
President
RetireReady Solutions
President
Re: Caption goes outside of bounderies
You could check if the left axis title fits in the chart height and wrap the text accordingly. Ie:
procedure TForm1.Chart1Resize(Sender: TObject);
var oneLineTitle: String;
titleHeight: Integer;
oneLineTitle:=StringReplace(Chart1.Axes.Left.Title.Text, sLineBreak, '', [rfReplaceAll]);
Chart1.Canvas.AssignFont(Chart1.Axes.Left.Title.Font);
if Chart1.Height < Chart1.Canvas.TextWidth(oneLineTitle) then
Chart1.Axes.Left.Title.Text:=WrapText(oneLineTitle, sLineBreak, [' '], Chart1.Height div Chart1.Axes.Left.Title.Font.Size)
Chart1.Axes.Left.Title.Text:=oneLineTitle;
titleHeight:=Abs((Chart1.Axes.Left.Title.Text.CountChar(#13)+1)*Chart1.Axes.Left.Title.Font.Height);
Chart1.MarginLeft:=Round((titleHeight+5)*100/Chart1.Width);
Thank you for your response.
I have this problem in a dozen+ charts.
Could a future version have a .WrapText property? That would be easier.
Ed Dressel
President
President
Your solution works well with the rendering of the TChart, but when creating an image, it does not work. See the attached demo, which has a TImage one third the height of the chart, but the caption does not size correctly.
How could this be done for rendering to an image?
Thank you,
Ed Dressel
Thank you,
Ed Dressel
- Axis Caption.zip
- (7.43 KiB) Downloaded 765 times
Ed Dressel
President
President
Sorry for the delay here.
You could create a new method (ie
Ie:
WrapLeftAxisTitle
) and move the code from the OnResize
event to it. Then, you only have to add a few parameters to it and call it both at OnResize
event and in your AssignChartToGraphic
method.Ie:
We are a lot closer, but not quite there: if the legend is in the way (on the top or bottom) and has a large number of items in it, the caption can get truncated.
To reproduce this change the line in the constructor so that there are 20 sample values:
Thank you,
Ed Dressel
Series1.FillSampleValues(20);
Ed Dressel
Ed Dressel
President
President
You could wrap the text to fit the length you wish. In this case you may want to use
ChartRect.Height
. Ie:
procedure TForm1.WrapLeftAxisTitle(aChart: TChart; const aHeight: Integer);
lOneLineTitle: String;
lTitleHeight: Integer;
lTitle: TChartAxisTitle;
lHeight: Integer;
Assert(aChart <> nil);
aChart.Draw;
lTitle := aChart.Axes.Left.Title;
lOneLineTitle := StringReplace(lTitle.Text, sLineBreak, ' ', [rfReplaceAll]);
lOneLineTitle := StringReplace(lOneLineTitle, ' ', ' ', [rfReplaceAll]);
aChart.Canvas.AssignFont(lTitle.Font);
lHeight:=aHeight;
if (aChart.Legend.Alignment=laTop) or (aChart.Legend.Alignment=laBottom) then
lHeight:=aChart.ChartRect.Height*aHeight div aChart.Height;
if lHeight < aChart.Canvas.TextWidth(lOneLineTitle) then
lTitle.Text := WrapText(lOneLineTitle, sLineBreak, [' '], lHeight div lTitle.Font.Size)
lTitle.Text := lOneLineTitle;
lTitleHeight:=Abs( (lTitle.Text.CountChar(#13) + 1) * lTitle.Font.Height);
aChart.MarginLeft := Round((lTitleHeight + 5) * 100 / aChart.Width);
Perfect. Thank you for the quick response.
Ed Dressel
President
President
