Tee Recompile/Indy
Bruce
Tee Recompile/Indy
Post by Bruce » Sun Sep 18, 2022 4:28 pm
I have removed the default Indy installation in Delphi 10.4.2 and installed a more recent version of it. but the Recompile program is using the default Indy path. How can I change this?
Re: Tee Recompile/Indy
Post by Yeray » Mon Oct 17, 2022 5:16 pm
Sorry for the delay here.
Have you solved the problem?
Have you tried to rebuild the packages manually?
Just to be sure we do the same, did you update Indy following the instructions here?
