Cannot recompile Delphi package: Tee928.dpk
Posted: Thu Oct 06, 2022 12:10 pm
by 16594532
Hello everyone,
I just registered as a new user of TeeChart. Before that, I have been using the version that comes with the IDE, so I don't know much about the installation of TeeChart.
I downloaded the latest source files and binaries, do I need to install both?
When I installed the source file program, it was prompted to compile, and it started to execute after I modified the path, but an error occurred:
TeeChart Pro
Compilation started: 2022/10/6 18:39:16
Win32 v28 (Delphi 11 and C++Builder 11 Update 2) (C++) ERROR
Tee928
Compiling...
"C:\Program Files (x86)\Embarcadero\Studio\22.0\bin\dcc32.exe" -$D+ -$L+ -$W+ -$O- -$C- -$Y+ -$C+ -$R+ -$Q+ -GD -V -VT -VN -W^ -H -$A8 --no-config -u"C:\Program Files (x86)\Embarcadero\Studio\22.0\Lib\win32\Release" -u"C:\Program Files (x86)\Embarcadero\Studio\22.0\Lib\win32\Release\Indy10" -nsSystem;WinAPI;VCL;System.Win;VCL.Imaging;Data;BDE;Datasnap;XML;VCLTee -LN"C:\Program Files (x86)\Steema Software\Steema TeeChart Pro VCL FMX Source Code 2022.36\Source\..\Compiled\Delphi28.win32\Lib" -E"C:\Program Files (x86)\Steema Software\Steema TeeChart Pro VCL FMX Source Code 2022.36\Source\..\Compiled\Delphi28.win32\bin" -N0"C:\Program Files (x86)\Steema Software\Steema TeeChart Pro VCL FMX Source Code 2022.36\Source\..\Compiled\Delphi28.win32\Lib" -U"C:\Program Files (x86)\Steema Software\Steema TeeChart Pro VCL FMX Source Code 2022.36\Source\..\Compiled\Delphi28.win32\Lib";"C:\Program Files (x86)\Embarcadero\Studio\22.0\Lib\win32\Debug";"C:\Program Files (x86)\Steema Software\Steema TeeChart Pro VCL FMX Source Code 2022.36\Source\VCL" -I"C:\Program Files (x86)\Steema Software\Steema TeeChart Pro VCL FMX Source Code 2022.36\Source\VCL" -R"C:\Program Files (x86)\Steema Software\Steema TeeChart Pro VCL FMX Source Code 2022.36\Source\VCL" -O"C:\Program Files (x86)\Embarcadero\Studio\22.0\Lib\win32\Debug" -M -DBCB --BCB -CG -JPHNE -JL -NO"C:\Program Files (x86)\Steema Software\Steema TeeChart Pro VCL FMX Source Code 2022.36\Source\..\Compiled\Delphi28.win32\Lib\Obj" -NH"C:\Program Files (x86)\Steema Software\Steema TeeChart Pro VCL FMX Source Code 2022.36\Source\..\Compiled\Delphi28.win32\Include" -NB"C:\Program Files (x86)\Steema Software\Steema TeeChart Pro VCL FMX Source Code 2022.36\Source\..\Compiled\Delphi28.win32\Lib\Obj" -LN"C:\Program Files (x86)\Steema Software\Steema TeeChart Pro VCL FMX Source Code 2022.36\Source\..\Compiled\Delphi28.win32\Lib" "C:\Program Files (x86)\Steema Software\Steema TeeChart Pro VCL FMX Source Code 2022.36\Source\VCL\Tee928.dpk" -LE"C:\Program Files (x86)\Steema Software\Steema TeeChart Pro VCL FMX Source Code 2022.36\Source\..\Compiled\Delphi28.win32\System"
Embarcadero Delphi for Win32 compiler version 35.0
Copyright (c) 1983,2022 Embarcadero Technologies, Inc.
VCLTee.TeeConst.pas(1014) Error: E1057 Implicit string cast from 'AnsiChar' to 'string'
Tee928.dpk(35) Fatal: F2063 Could not compile used unit 'VCLTee.TeeConst.pas'
EXCEPTION:
Compilation aborted.
Does anyone know where the problem is?
Re: Cannot recompile Delphi package: Tee928.dpk
Posted: Thu Oct 06, 2022 1:54 pm
That's strange. It builds without issues for me:
Can you try downloading the installer again?
Posted: Thu Oct 06, 2022 11:42 pm
by 16594532
Thanks for the reply.
I still encountered the same error message after re-downloading and installing, my IDE version is RAD Studio 11.2 Patch 1 (28.0.46141.0937).
Posted: Fri Oct 07, 2022 6:23 am
Could you please check if the line 1014 in the "Source\TeeConst.pas" is as follows?
  TeePolarDegreeSymbol        :='°';
Posted: Fri Oct 07, 2022 7:23 am
by 16594532
No, in notepad++ it looks like gibberish:
Posted: Fri Oct 07, 2022 10:29 am
by 16594532
I need your help.
I tried to use hexadecimal characters to represent this gibberish-looking symbol, but I found two symbols in ASCII Code that are very similar to it, Should I choose #B0 or ​​#BA ?
Posted: Fri Oct 07, 2022 1:52 pm
It's the degree symbol/sign, B0
Posted: Fri Oct 07, 2022 4:58 pm
by 16594532
I changed line 1014 to:
TeePolar Degree Symbol :=#$B0;
Compile again, an error is reported on line 612, it seems that '©' is not correctly recognized.
So I replace it with #$A9:
TeeMsg_Copyright          :={$IFDEF LCL}'(C)'{$ELSE}#$A9{$ENDIF}+' 1995-2022 by Steema Software';
continue to compile, this time it returns to line 1014 to report an error:
VCLTee.TeeConst.pas(1014) Error: E1057 Implicit string cast from 'AnsiChar' to 'string'.
I don't know where the problem is, so I had to copy and paste the code you showed above and continue compiling. This time it was the VCLTee.TeeFormatting.pas file, line 612, and I opened it and found that it seemed to have the same problem as the VCLTee.TeeConst.pas file, line 1014, which made I feel very sad, what's the problem?
This is my system information: Windows 11 enterprise, version 22H2 Build 22621.521, Simplified Chinese, is there something wrong with my operating system character set?
Would you give me a version that compiles fine?
Posted: Mon Oct 10, 2022 7:58 am
Indeed, we detected some unicode issues with Chinese machines. We'll revise that.
In the meanwhile, you should be able to correct the "Source\TeeConst.pas" is as follows and run TeeRecompile:
Line 612:
TeeMsg_Copyright :={$IFDEF LCL}'(C)'{$ELSE}'©'{$ENDIF}+' 1995-2022 by Steema Software';
Line 1014:
Posted: Thu Oct 13, 2022 1:50 pm
An alternative is to change your system locale as follows:
