Problem saving in emf
Jonp
Post by Jonp » Thu Oct 20, 2022 12:32 pm
I am trying to export charts to files of various formats . Most work fine. However, while wmf export is ok, the emf crashes in the Winapi.GDIPOBJ in the following function
function TGPGraphics.MeasureString(string_: WideString; length: Integer; font: TGPFont;
       const origin: TGPPointF; out boundingBox: TGPRectF): TStatus;
  var
    nFont: GpFont;
    rect: TGPRectF;
    if assigned(font) then nfont := font.nativeFont else nfont := nil;
    rect.X := origin.X;
    rect.Y := origin.Y;
    rect.Width := 0.0;
    rect.Height := 0.0;
    result := SetStatus(GdipMeasureString(
        nativeGraphics,
        PWideChar(string_),
        length,
        nfont,
        @rect,
        nil,
        @boundingBox,
        nil,
        nil
The file is generated, though.
The teechart version is Pro 2022.36
My code is simply:
Case SaveDialog.FilterIndex of
                    1:  qualitychart.SaveToBitmapFile(SaveDialog.FileName);     // BMP
                    2:  begin   // JPG
                         With GetChartJPEG(Qualitychart) do
                         try
                          SaveToFile(savedialog.filename);    { <-- save the JPEG to disk }
                         finally
                          Free;  { <-- free the temporary JPEG object }
                    3:  Qualitychart.SaveToMetafile(SaveDialog.FileName);    // WMF
                    4:  Qualitychart.SaveToMetafileEnh(SaveDialog.FileName) ;    //EMF
                    5:  TeeSaveToPNG(QualityChart,SaveDialog.FileName);    // png
                    6:  TeeSaveToPDFFile(QualityChart,savedialog.FileName);   // pdf
                  End;
Best,
Jon
Re: Problem saving in emf
Post by Yeray » Wed Nov 02, 2022 1:49 pm
Hello Jon,
I can't reproduce the problem.
Jonp
Post by Jonp » Fri Dec 09, 2022 11:58 am
Sorry for not answering before. The way to get to the save is rather complex, so I have to figure out a way to reproduce the error in a simple example.
But: the problem does not seem to be your fault, at least not totally.
It also crashes if I use
metafile:=QualityChart.TeeCreateMetafile(False,Qualitychart.clientRect);
 metafile.SaveToFile(SaveDialog.FileName) ;
but it does not crash in the save routines themselves, that is, both the TeeCreateMetaFile and the SaveToMetafile complete without any quarrel.
Interestingly, the program does not crash if I do the following:
  TeeSaveToPNG(Qualitychart,'$$$$$.png');
That is, save to a PNG (or any other format except wmf and emf) after having saved to emf/wmf.
Thus, it seems that some cleanup that the other file routines fixes the problem.
Best,
Jon
Post by Yeray » Mon Dec 12, 2022 1:35 pm
Hello Jon,
I've tried both SaveToMetafile and TeeCreateMetafile + SaveToFile with a new simple example project and I get no errors here.
Just add a TChart and a TButton to the form and this code:
uses Series;
  with Chart1 do
    Legend.Hide;
    Color:=clWhite;
    Gradient.Visible:=False;
    Walls.Back.Color:=clWhite;
    AddSeries(TBarSeries).FillSampleValues;
var metafile: TMetafile;
  Chart1.SaveToMetafile('E:\tmp\exports\metafiletest_vcl.wmf');
  metafile:=Chart1.TeeCreateMetafile(False, Chart1.ClientRect);
  metafile.SaveToFile('E:\tmp\exports\metafiletest_vcl2.wmf') ;
