Bar Chart self-stacked title vertical position
Posted: Wed Dec 07, 2022 4:36 am
by 16566546
In my previous topic, I was asking about the correct horizontal placement of a title above a self-stacked bar chart. In this post, I would like to be able to set the vertical position of the title just above the top axis of the bar chart, and have it remain there on scroll or zoom operations. As shown in the attached images, the title scrolls off the top of the chart at present if I use CalcBarBounds, or disappear entirely if I zoom the chart.
Any suggestions much appreciated.
Best regards
Errol
Re: Bar Chart self-stacked title vertical position
Posted: Fri Dec 09, 2022 6:17 pm
Taking the code from the reply I just wrote
there, I've modified it to also calculate the value for the
TAnnotationTool.Top
property to position them just above the
ChartRect
- Project1_2022-12-09_19-17-13.png (15.97 KiB) Viewed 6597 times
uses Series, TeeTools;
const aWellName: array[0..2] of string = ('AT-602', 'AT-501', 'AT-401');
var i, j: Integer;
Chart1.Title.Hide;
Chart1.View3D:=False;
Chart1.Color:=clWhite;
Chart1.Legend.Hide;
for i:=0 to 2 do
MultiBar:=mbSelfStack;
Marks.Hide;
for j:=0 to 4 do
Add(5+Random*5);
with TAnnotationTool(Chart1.Tools.Add(TAnnotationTool)) do
Shape.CustomPosition := true;
Shape.Pen.Color := clWhite;
Shape.Transparent := true;
Shape.Font.Size := 10;
Shape.Font.Style := Shape.Font.Style + [fsBold];
Shape.Angle := 90;
Text := aWellName[i];
OnBeforeDraw:=AnnotationToolBeforeDraw;
Chart1.MarginTop:=10;
Chart1.Draw;
procedure TForm1.AnnotationToolBeforeDraw(Sender: TObject);
var i: Integer;
for i:=0 to Chart1.Tools.Count-1 do
if Sender = Chart1.Tools[i] then
PlaceWellNames(i);
Exit;
procedure TForm1.PlaceWellNames(AIndex: Integer);
LLeft, LWidth: integer;
LAcross: integer;
annot: TAnnotationTool;
bar: TBarSeries;
if Chart1.Tools[AIndex] is TAnnotationTool then
annot:=TAnnotationTool(Chart1.Tools[AIndex]);
bar:=TBarSeries(Chart1[AIndex]);
// centre of bar
LLeft := bar.CalcXPos(0) + (bar.BarWidth div 2);
LWidth := annot.Width; // width of shape
LAcross := LWidth div 2; // half title width
annot.PositionUnits := muPixels;
annot.Left := LLeft - LAcross; // this is correct for non-automatic scaling
annot.Top := Chart1.ChartRect.Top - LAcross - 10;
