Save a Chart EMF to a MemoryStream?
FAB Soft
Post by FAB Soft » Thu Jan 13, 2005 10:47 pm
We are using TeeCharts 5.03 for Delphi7. Is there any way to save a Chart as an EMF to a MemoryStream? In the same vein as SaveToMetafileEnh(Filename), it would be nice if it could be saved to a MemoryStream instead. The stream can then be used elsewhere instead of having to create a disk file and then read it immediately in to a stream, which seems a little unneccessary.
Nic
Marjan
Post by Marjan » Fri Jan 14, 2005 7:51 am
Hi, Nic.
Yes, sure, it ca be done. Example
var tmpMeta: TMetafile;
  tmpMeta := Chart1.TeeCreateMetafile(false,Chart1.ClientRect);
  try
    tmpMeta.SaveToStream(your_stream_comes_here);
  finally
    tmpMeta.Free;
Marjan Slatinek,
