Surface chart grows in size when starting to rotate
hcknobel
Post by hcknobel » Thu Nov 30, 2023 4:09 pm
I have a VCLTee.TeeSurfa 3D surface chart using the Athens version of Delphi and the latest teeChart version. I define my chart to be about half the size of the containing panel, and with the Rotate tool. When I first display the chart at runtime, it is the designed size. However, as soon as I start dragging it to rotate it, it jumps to about a 50% larger size in all 3 dimensions. How do I prevent this resizing?
Re: Surface chart grows in size when starting to rotate
Post by Yeray » Mon Dec 04, 2023 7:32 am
The TRotationTool modifies the Rotation and the Elevation properties, but to do so, it also sets Orthogonal property to False.
Sometimes, setting your starting view with Orthogonal:=False avoids that jump when using the TRotationTool.
hcknobel
Post by hcknobel » Tue Dec 05, 2023 1:08 am
Thank you very much. That worked.
