Problem with PDF export
Posted: Tue Jan 30, 2024 9:03 pm
by 16595162
I have some charts that need to be saved as PDF. For the export I added the unit VCLTee.TeePDFCanvas to the uses list. Than I call TeeSaveToPDFFile(Chart, Filename).
Attached I added an example of a pie chart how it looks on screen and how it looks inside the pdf (using the original adobe reader). As said it's just an example. The exports are most of the times are not correct. Parts are missing or wrong painted.
I use the latest version of TeeChartVCL Pro (2023.39).
Any idea what's going wrong? Our customer want us to create automaticaly PDF files from all the charts we built for them. All charts are designed with TeeChart. So we need a reliable solution.
Re: Problem with PDF export
Posted: Thu Feb 01, 2024 8:59 am
I've been able to reproduce the problem so I've added it to the public tracker (#2669).
Thanks for reporting it.
