We produce graphics like in the attached plot with TChart, where we use a ColorGrid plus 3 Line Series.
Usually we display the Colors of the Color Grid in the Legend. Now we want in addition to show a legend for the 3 Line Series. But when we include the Line Series in the Legend the Color Grid colors are vanishing, see attachment.
How can we have the Color Grid colors Legend AND a Legend for the Line Series?
Thanks and best regards
How to get correct Legend for ColorGrid AND Line Series
- Legend1CaptureNew.png (404.6 KiB) Viewed 731 times
- Legend2Capture.PNG (198.18 KiB) Viewed 731 times
Re: How to get correct Legend for ColorGrid AND Line Series
When the legend shows the palette, I don't see a lot of space to show any other item. Then, the ExtraLegendTool may be the most appropriate solution for this.
See the example here.
Hello Yeray,
Thanks for the quick response, that indeed seems to be a way to proceed.
But how can I make sure to just just show the 3 Line Series in THAT extra legend?
Best regards,
Thomas
Best regards,
Thomas
To phrase this question differently, how can I explicitly decide in which of both (or more) Legends any Series is shown?
Because Series.ShowInLegend is global for all Legends.
You could do something similar to the discussed here.
uses TeEngine, Chart, Series, TeeSurfa, TeeExtraLegendTool;
type TMyExtraLegendTool=class(TExtraLegendTool)
protected
procedure ChartEvent(AEvent: TChartToolEvent); override;
TLegendAccess=class(TChartLegend);
var Chart1: TChart;
procedure TMyExtraLegendTool.ChartEvent(AEvent: TChartToolEvent);
var i: Integer;
if AEvent=cteAfterDraw then
for i:=0 to ParentChart.SeriesCount-1 do
ParentChart[i].ShowInLegend:=ParentChart[i] is TLineSeries;
if Assigned(ParentChart) and Assigned(Series) then
if Legend.Visible then
TLegendAccess(Legend).CalcRect;
Legend.DrawLegend;
procedure TForm1.Chart1BeforeDrawChart(Sender: TObject);
var i: Integer;
Chart1[i].ShowInLegend:=Chart1[i] is TColorGridSeries;
var i: Integer;
Chart1:=TChart.Create(Self);
with Chart1 do
Parent:=Self;
Align:=alClient;
Color:=clWhite;
Gradient.Visible:=False;
Walls.Back.Color:=clWhite;
View3D:=False;
OnBeforeDrawChart:=Chart1BeforeDrawChart;
with TColorGridSeries(Chart1.AddSeries(TColorGridSeries)) do
Pen.Hide;
FillSampleValues;
for i:=0 to 1 do
with TLineSeries(Chart1.AddSeries(TLineSeries)) do
Pen.Width:=2;
FillSampleValues;
Chart1.Draw;
with TMyExtraLegendTool(Chart1.Tools.Add(TMyExtraLegendTool)) do
Series:=Chart1[1];
Legend.LegendStyle:=lsSeries;
Legend.Left:=Chart1.Legend.Left;
Legend.Top:=Chart1.ChartRect.Top;
Thanks a lot, we are practically there:
I am setting the Position in the Create of the form but it looks like I need to update the position of the
extra legend before the painting.
One other quick question, how can I change/influence the texts that are shown in the Extra legend, I'd like to have other text than names of the Series?
You'd have one extra series for each entry you want to show in the legend. You can set their
Knowing their indexes, you could modify the code in the
Yes, that's why I called
Draw
before creating the TExtraLegendTool
at OnCreate
in the example above.We use to recommend adding extra dummy series to be shown in the legend.
Color
property to match the colors of the main series, setting your custom Title
to them, but without adding any data to them.Knowing their indexes, you could modify the code in the
to only activate ShowInLegend
property for those dummy series.Best Regards,
Ok, I just had to populate the Title properties of the Line Series, all perfect now, thanks!
