How to get correct Legend for ColorGrid AND Line Series
Posted: Wed Apr 03, 2024 1:59 pm
by 16594956
We produce graphics like in the attached plot with TChart, where we use a ColorGrid plus 3 Line Series.
Usually we display the Colors of the Color Grid in the Legend. Now we want in addition to show a legend for the 3 Line Series. But when we include the Line Series in the Legend the Color Grid colors are vanishing, see attachment.
How can we have the Color Grid colors Legend AND a Legend for the Line Series?
Thanks and best regards
Re: How to get correct Legend for ColorGrid AND Line Series
Posted: Thu Apr 04, 2024 7:12 am
When the legend shows the palette, I don't see a lot of space to show any other item. Then, the ExtraLegendTool may be the most appropriate solution for this.
See the example here.
Posted: Thu Apr 04, 2024 7:36 am
by 16594956
Hello Yeray,
Thanks for the quick response, that indeed seems to be a way to proceed.
But how can I make sure to just just show the 3 Line Series in THAT extra legend?
Best regards,
Thomas
Posted: Thu Apr 04, 2024 2:03 pm
by 16594956
To phrase this question differently, how can I explicitly decide in which of both (or more) Legends any Series is shown?
Because Series.ShowInLegend is global for all Legends.
Posted: Thu Apr 04, 2024 8:42 pm
You could do something similar to the discussed here.
uses TeEngine, Chart, Series, TeeSurfa, TeeExtraLegendTool;
type TMyExtraLegendTool=class(TExtraLegendTool)
  protected
    procedure ChartEvent(AEvent: TChartToolEvent); override;
TLegendAccess=class(TChartLegend);
var Chart1: TChart;
procedure TMyExtraLegendTool.ChartEvent(AEvent: TChartToolEvent);
var i: Integer;
  if AEvent=cteAfterDraw then
    for i:=0 to ParentChart.SeriesCount-1 do
        ParentChart[i].ShowInLegend:=ParentChart[i] is TLineSeries;
    if Assigned(ParentChart) and Assigned(Series) then
      if Legend.Visible then
        TLegendAccess(Legend).CalcRect;
        Legend.DrawLegend;
procedure TForm1.Chart1BeforeDrawChart(Sender: TObject);
var i: Integer;
      Chart1[i].ShowInLegend:=Chart1[i] is TColorGridSeries;
var i: Integer;
  Chart1:=TChart.Create(Self);
  with Chart1 do
    Parent:=Self;
    Align:=alClient;
    Color:=clWhite;
    Gradient.Visible:=False;
    Walls.Back.Color:=clWhite;
    View3D:=False;
    OnBeforeDrawChart:=Chart1BeforeDrawChart;
  with TColorGridSeries(Chart1.AddSeries(TColorGridSeries)) do
    Pen.Hide;
    FillSampleValues;
  for i:=0 to 1 do
  with TLineSeries(Chart1.AddSeries(TLineSeries)) do
    Pen.Width:=2;
    FillSampleValues;
  Chart1.Draw;
  with TMyExtraLegendTool(Chart1.Tools.Add(TMyExtraLegendTool)) do
    Series:=Chart1[1];
    Legend.LegendStyle:=lsSeries;
    Legend.Left:=Chart1.Legend.Left;
    Legend.Top:=Chart1.ChartRect.Top;
Posted: Fri Apr 05, 2024 9:38 am
by 16594956
Thanks a lot, we are practically there:
I am setting the Position in the Create of the form but it looks like I need to update the position of the
extra legend before the painting.
One other quick question, how can I change/influence the texts that are shown in the Extra legend, I'd like to have other text than names of the Series?
Posted: Fri Apr 05, 2024 9:55 am
Yes, that's why I called Draw before creating the TExtraLegendTool at OnCreate in the example above.
We use to recommend adding extra dummy series to be shown in the legend.
You'd have one extra series for each entry you want to show in the legend. You can set their Color property to match the colors of the main series, setting your custom Title to them, but without adding any data to them.
Knowing their indexes, you could modify the code in the TMyExtraLegendTool.ChartEvent to only activate ShowInLegend property for those dummy series.
Posted: Fri Apr 05, 2024 10:07 am
by 16594956
Ok, I just had to populate the Title properties of the Line Series, all perfect now, thanks!
