Surface Series from multiple line series?
NREL
Post by NREL » Thu Jan 20, 2005 8:27 am
Is it possible to create a SurfaceSeries from multiple LineSeries?
If I have LineSeries1 and LineSeries2 both with same X values, can I create a SurfaceSeries that has these values with Z=1 and Z=2; that is,
Given
LineSeries1 constructed by:
LineSeries1.AddXY(X1,Y1)
LineSeries2 constructed by:
LineSeries2.AddXY(X1,Y2)
Is thers a function so that SurfaceSeries = LineSeries1 (z=1) x LineSeries2 (z=2)
I would like to be able to switch from a family of curves to a surface plot quickly without having to reformat the data.
Marjan
Post by Marjan » Thu Jan 20, 2005 11:20 am
Hi.
Yes, providing all series have the same number of points and (more importantly), all series have the same x values. If this condition is satisfied, you can use TSurfaceSeries.AddXYZ method to add points from individual series. Example
surface1.Clear;
for i:= Low(X1) to High(X1) do surface1.AddXYZ(X1[i],Y1[i],1.0);
for i:= Low(X1) to High(X1) do surface1.AddXYZ(X1[i],Y2[i],1.0);
You can also copy the values directly from series XValues and Yvalues list(s).
Marjan Slatinek,
Post by Narcís » Thu Jan 20, 2005 11:28 am
Hi NREL,
As an example, you can place a Chart with a Surface Series on a form, a button and do something like:
  private
    { Private declarations }
    XValues: array[0..19] of double;
    YValues: array[0..19] of double;
    ZValues: array[0..19] of double;
    flag: boolean;
var
  count,i: integer;
  X,Y,Z: integer;
    count:=0;
    flag:=false;
    Randomize;
    for X := 0 to 9 do
      for Z := 0 to 1 do
        Y := Random(100);
        XValues[count] := X;
        ZValues[count] := Z;
        YValues[count] := Y;
        inc(count);
    for i:=0 to 19 do
      series1.AddXYZ(XValues[i], YValues[i], ZValues[i]);
		Chart1.Axes.Depth.Visible := true;
var
  count,i,j: integer;
  X,Z: integer;
  Surface: TSurfaceSeries;
  count:=0;
  Chart1.RemoveAllSeries;
  flag := not flag;
  if (flag) then
    for i:=0 to 1 do
      Chart1.AddSeries(TLineSeries);
    for X:=0 to 9 do
      for Z:=0 to 1 do
        Chart1[1-Z].AddXY(X, YValues[count]);
        inc(count);
  end
    Surface:=TSurfaceSeries.Create(self);
    Chart1.AddSeries(Surface);
    for j:=0 to 19 do
      Surface.AddXYZ(XValues[j], YValues[j], ZValues[j]);
SteveP
Post by SteveP » Fri Jan 21, 2005 2:22 pm
In the LineSeries view, can the depth of each individual line be made only 1 pixel (like if viewed in 2D) instead of being a ribbon whose width equals the spacing between each series on the depth axis ?
Marjan
Post by Marjan » Sun Jan 23, 2005 3:58 pm
Hi, Steve.
Yes, sure. Use the following code:
  Series1.Depth := 0;
  Series1.LinePen.Color := clRed;
  Series2.Depth := 0;
  Series2.LinePen.Color := clGreen;
Or alternatively, simply switch from line to fastline series.
Marjan Slatinek,
