Charts with Bars with Negative values
Posted: Thu Dec 19, 2024 7:36 pm
by 16596488
In the attached demo, I have a TChart that has bars, some with negative values.
The image is visible here:
https://app.screencast.com/iyBZFNk6yvUsB
I have two items I need help with.
1) For the first red bar with a negative value, there is no margin between the red and the axis--how do I create a margin between the red bar and the line at the bottom?
2) For the left axis, I want the zero value line to be the darker/heavier line, and the other lines to be lighter.
How can I achieve this?
Ed Dressel
Re: Charts with Bars with Negative values
Posted: Fri Dec 20, 2024 9:29 am
Hello Ed,
Ed Dressel wrote: ↑Thu Dec 19, 2024 7:36 pm
You can add some offset to the left axis:
Chart1.Axes.Left.MaximumOffset:=10;
Chart1.Axes.Left.MinimumOffset:=10;
You can move the Bottom with the
PositionPercent
property calculating the position of the 0 value in pixels as follows:
Chart1.Axes.Bottom.PositionUnits:=muPixels;
Chart1.OnBeforeDrawAxes:=AxesBeforeDraw;
Chart1.Draw;
procedure TForm1.AxesBeforeDraw(Sender: TObject);
Chart1.Axes.Bottom.PositionPercent:=Chart1.ChartRect.Bottom - Chart1.Axes.Left.CalcPosValue(0);
The problem is that, moving the bottom axis to the middle of the chart, then the labels are drawn behind the bars, and you probably don't want that.
There's a
Axes.Behind
property you can set to
False
, but then the left axis grid will also be drawn on top of the bars, which you probably don't want.
Then, the trick is to play with
OnBeforeDrawChart
and
AfterDrawValues
events to disable and enable those properties. Ie:
Chart1.OnBeforeDrawChart:=ChartBeforeDraw;
Series1.AfterDrawValues:=SeriesAfterDraw;
procedure TForm1.ChartBeforeDraw(Sender: TObject);
Chart1.Axes.Behind:=True;
Chart1.Axes.Bottom.Texts.Font.Color:=clNone;
Chart1.Axes.Left.Grid.Visible:=True;
procedure TForm1.SeriesAfterDraw(Sender: TObject);
Chart1.Axes.Behind:=False;
Chart1.Axes.Bottom.Texts.Font.Color:=clBlack;
Chart1.Axes.Left.Grid.Visible:=False;
- BottomAxisMoved.png (12.78 KiB) Viewed 24528 times
Posted: Fri Dec 20, 2024 3:45 pm
by 16596488
Thank you. That works well--but is there any way to move the series labels (e.g. "2 Years Before") below the chart, rather than overwriting the series)?
Posted: Mon Dec 23, 2024 7:22 am
Hello Ed,
Ed Dressel wrote: ↑Fri Dec 20, 2024 3:45 pm
That's easier. You only need to hide the Bottom axis pen and add a
TColorLineTool
- BottomAxisColorLine.png (13.29 KiB) Viewed 23449 times
uses VCLTee.TeeTools;
var ColorLine1: TColorLineTool;
Chart1.Axes.Bottom.Axis.Hide;
ColorLine1:=TColorLineTool(Chart1.Tools.Add(TColorLineTool));
ColorLine1.AllowDrag:=False;
ColorLine1.DragRepaint:=True;
ColorLine1.Axis:=Chart1.Axes.Left;
ColorLine1.Value:=0;
