Marks within Bars
sm
Marks within Bars
Post by sm » Tue Apr 19, 2005 8:34 am
Situation: Chart with two series of kind TBarJoinSeries which are stacked 100%.
I want to display the value of each bar within the bar itself. Is that possible and how would I do this?
TeeChart is version 7.02 for Delphi 7.
Post by Narcís » Tue Apr 19, 2005 8:51 am
Hi sm,
Yes, one easy way of doing that is setting marks arrowlength to a negative value like in the example below:
var
  i: Integer;
  Chart1.AddSeries(TBarJoinSeries.Create(self));
    With Chart1[i] do
      FillSampleValues();
      Marks.Arrow.Visible:=false;
      Marks.ArrowLength:=-50;
  (Chart1[0] as TBarJoinSeries).MultiBar:=mbStacked100;
sm
Post by sm » Tue Apr 19, 2005 9:33 am
narcis wrote:Hi sm,
var
  i: Integer;
    With Chart1[i] do
      FillSampleValues();
Thanks! But I would still have to calculate the arrow length by myself if I I want to center the marks. Also a hardcoded value for ArrowLength would not work if the bars values can be very small (the mark would slip into another bar).
Post by Narcís » Tue Apr 19, 2005 11:01 am
Hi sm,
Ok, you can play with series values positions in the chart, ChartRect settings, series marks positions, etc. Find an example below:
var
  i: Integer;
    Chart1[i].FillSampleValues();
  Chart1.Draw;
  CustomSeriesMarks;
procedure TForm1.CustomSeriesMarks;
var
  i,j: Integer;
  APosition:TSeriesMarkPosition;
  APosition:=TSeriesMarkPosition.Create;
  try
    for j:=0 to Chart1.SeriesCount-1 do
      for i:=0 to Chart1[j].Count-1 do
        APosition.Custom:=True;
        APosition.LeftTop.X:=Chart1[j].Marks.Positions[i].LeftTop.X;
        if (j=0) then
          APosition.LeftTop.Y:=Chart1[j].CalcYPos(i) +
                            ((Chart1[j+1].CalcYPos(i) -
                              Chart1[j].CalcYPos(i)) div 2)
                            ((Chart1.ChartRect.Bottom -
                              Chart1[j].CalcYPos(i)) div 2);
        Chart1[j].Marks.Positions[i]:=APosition;
  finally
      APosition.Free;
