FInding x0,y0,x1,y1 for ArrowHead Series
Satish
Post by Satish » Wed Apr 27, 2005 12:45 pm
I have Series1 (TCandleSeries) & Series2(TLIneSeries). Series1 is displayed as a High-Low-Close bar. I need to plot arrows at points where the Series2 intersects Series1. Given that I know the series index at which the intersection occurs, how do I compute x0,y0,x1 & y1 coordinates - I believe they are screen coordinates.
I wish to draw the arrow above the high of the high-low-close bar or below the low of the high-low-close bar. Also how do I ensure that arrows for all other non-intersecting points are not visible. Do I make the arrow color same as chart background color ?
Will appreciate help/suggestions.
Satish
Marjan
Post by Marjan » Thu Apr 28, 2005 11:50 am
Hi.
If both series share the same x values then if you know Series2 (or Series1) ValueIndex, you also know intersection x and y value. Example:
var x,y: double;
  x := Series2.XValues[Index];
  y := Series2.YValues[Index];
On the other hand, if you want to transform real x,y coordinates back to screen coordinates, you can use TChartSeries.CalcXPos and TChartSeries.CalcYPos method. Example:
var x0,y0: Integer;
  x0 := Series2.CalcXPos(Index);
  y0 := Series2.CalcYPos(Index);
This works fine for line, bar and point series. If series has more than two chart value lists (x,high, low, open ... values), a bit more complex code is needed. In the example below arrows will be drawn above every visible candle:
// using tChart OnAfterDraw event !
var i: Integer;
  FromPoint,ToPoint: TPoint;
  Chart1.Canvas.ClipRectangle(Chart1.ChartRect);
  With Series1 do // Series1 is TCandleSeries
    for i := FirstValueIndex to LastValueIndex do
      ToPoint.X := CalcXPos(i);
      ToPoint.Y := CalcYPosValue(HighValues.Value[i]);
      FromPoint.X := ToPoint.X;
      FromPoint.Y := ToPoint.Y - 20;
      ParentChart.Canvas.Arrow(True,FromPoint,ToPoint,7,7,MiddleZ);
  Chart1.Canvas.UnClipRectangle;
No simple way to do it. Calculate all intersection points and then draw arrow for individual intersection.
Marjan Slatinek,
Satish
Post by Satish » Thu Apr 28, 2005 3:59 pm
Marjan,
Thanks a lot, will try it out and confirm to you.
Satish
Satish
Post by Satish » Fri Apr 29, 2005 2:51 am
Marjan,
Using the canvas method how do I color the arrow - I need to color it either red or green ? Also is there a way to fill the Arrow Series with transparent arrows - Actually I would be using 8-10 red/green arrows in a series having over 250 points.
Satish
Marjan
Post by Marjan » Fri Apr 29, 2005 3:27 pm
Hi, Satish.
This can be done by adding the following lines to chart OnAfterDraw event:
  ParentChart.Canvas.Brush.Color := clRed;
  ParentChart.Canvas.Brush.Style := bsSolid;
Try setting arrow point color to clNone. But if you plan to use arrow series, there is a lot simpler solution : clear and repopulate arrow series when your data changes. Of course, you don't simply copy all points from original series, you only copy intersection points.
Marjan Slatinek,
