OnGetLegendText
AMS
OnGetLegendText
Post by AMS » Mon Aug 22, 2005 7:15 am
Hi all,
I have two bar series added to my chart, Series1 and Series2, ShowInLegend = true by default and legend checkbox enabled.
If the user un-checks Series2 from the legend checkbox and even thought the series is not visible on the chart, if the moves mouse over the chart where the series did have a point, the OnGetLegendText event fires with the properties from the invisible series item and the mark is displayed. Surely a hidden series should not show mark tips?
Got any solutions?
John.
Post by Narcís » Mon Aug 22, 2005 8:40 am
Hi John,
I haven't been able to reproduce what you report using latest TeeChart version available (v7.04). Which TeeChart version are you using? Could you please send us an example we can run "as-is" to reproduce the problem here? You can post your files at [url]news://www.steema.net/steema.public.attachments[/url] newsgroup.
AMS
Post by AMS » Thu Aug 25, 2005 5:27 am
Hi Narcis,
I have duplicated the problem using version 7.05. I am now not sure whether it is a TChart bug, rather it may be an implementation problem. Anyway, please take a look.
Here is the scenario:
- Draw 3 TLineSeries, with Legend->Checkbox->Visible.
- Move the mouse over the series points and the custom tool tip object shall display the constructed text on mouse move.
- Take note of a specific point XY location.
- Then unchecked the series, whose location you have taken note of, and run the mouse over that point.
- You will see that the ToolTip is still displayed. I dont want the tooltip to be displayed when the series is uncheked.
class TfrmMain : public TForm
__published:	// IDE-managed Components
  TChart *Chart;
  TChartEditor *ChartEditor;
  TPopupMenu *PopupMenu;
  TMenuItem *ChartProperties;
  void __fastcall FormShow(TObject *Sender);
  void __fastcall ChartPropertiesClick(TObject *Sender);
  void __fastcall FormDestroy(TObject *Sender);
  void __fastcall ChartMouseMove(TObject *Sender, TShiftState Shift, int X, int Y);
private:	// User declarations
  void __fastcall MarkToolGetText(TMarksTipTool* Sender, AnsiString &Text);
  TList         *ToolTips;
  AnsiString    SeriesName;
  TMarksTipTool *SeriesToolTipPtr;
public:		// User declarations
  __fastcall TfrmMain(TComponent* Owner);
__fastcall TfrmMain::TfrmMain(TComponent* Owner)
  : TForm(Owner)
  SeriesToolTipPtr              = new TMarksTipTool(Owner);
  SeriesToolTipPtr->ParentChart = Chart;
  SeriesToolTipPtr->MouseAction = mtmMove;
  SeriesToolTipPtr->Style       = smsValue;
  SeriesToolTipPtr->OnGetText   = MarkToolGetText;
void __fastcall TfrmMain::FormShow(TObject *Sender)
  TLineSeries *ptrToLineSeries;
  Chart->Legend->CheckBoxes = true;
  for( int i=0; i < 3; i++ )
    ptrToLineSeries = new TLineSeries(Chart);
    ptrToLineSeries->Title = "Series " + AnsiString(i);
    ptrToLineSeries->FillSampleValues(20);
    ptrToLineSeries->ShowInLegend = true;
    ptrToLineSeries->Pointer->Visible = true;
    Chart->AddSeries( ptrToLineSeries );
void __fastcall TfrmMain::ChartPropertiesClick(TObject *Sender)
  ChartEditor->Execute();
void __fastcall TfrmMain::ChartMouseMove(TObject *Sender,
  int ser_click = 0;
  SeriesName = "";
  for( int i=0; i < Chart->SeriesCount(); i++ )
    if( (Chart->SeriesList->Items[i]->ClassNameIs("TLineSeries")) ||
        (Chart->SeriesList->Items[i]->ClassNameIs("TFastLineSeries")) )
      ser_click = Chart->SeriesList->Items[i]->Clicked(X, Y);
      if( ser_click >= 0 )
        SeriesName = "Series Name: " + Chart->SeriesList->Items[i]->Title;
      } // if( ser_click >= 0 )
  } // for( int i=0; i < Chart->SeriesCount(); i++ )
void __fastcall TfrmMain::MarkToolGetText(TMarksTipTool* Sender, AnsiString &Text)
  SeriesName += "\rSeries Value: ";
  Text.Insert(SeriesName, 0);
Thanks in advance for the help,
Regards John.
Post by Narcís » Thu Aug 25, 2005 12:19 pm
Hi John,
Thanks for the code. I've been able to reproduce this problem and added the issue to our defect list to be considered for future releases. A workaround can be only filling the text to display if clicked series is visible, otherwise put a blank string on it. You will get the clicked series index at the MouseMove event.
AMS
Post by AMS » Fri Aug 26, 2005 6:08 am
Thanks Narcis,
I have included the fix here so that others may imlement the work around.
  TChart *Chart;
  bool          ShowToolTip;
  : TForm(Owner)
  int ser_click = 0;
  SeriesName = "";
      if( Chart->SeriesList->Items[i]->Visible == true )
        ser_click = -1;
        ShowToolTip = true;
  if( ShowToolTip )
    ShowToolTip = false;
    Text = "";
Regards, John.
