Divide function no longer works
Mikkel
Post by Mikkel » Thu Aug 25, 2005 10:01 pm
This code used to work with TeeChart 5 and 6, but no longer works with version 7:
I have programmatically added 2 database series, rDollarSeries and rUnitSeries (which display OK), and then added a new series called bSeries. This code should define bSeries as a calculation of the average price, ie Dollars/Units:
theDiv := TDivideTeeFunction.Create(ChartForm);
bSeries.SetFunction(theDiv);
bSeries.DataSources.Add(rDollarSeries);
bSeries.DataSources.Add(rUnitSeries);
bSeries.FunctionType.Period := 1;
But it no longer works :(
Is there a new technique for doing this ?
Post by Narcís » Fri Aug 26, 2005 8:04 am
Hi Mikkel,
You could try using bSeries.CheckDataSource after defining the datasources.
