TLegendScrollBar problems
trydal
Post by trydal » Fri Aug 26, 2005 8:47 am
Hi again.
I'm having problems adding the TLegendScrollBar at runtime.
Creation:
Self.FLegendScrollBar := TLegendScrollBar.Create(self);
Self.FLegendScrollBar.ParentChart := self;
Self.Tools.Add(Self.FLegendScrollBar);
Segfaults when the legend becomes visible (when I insert the first line) in:
procedure TLegendScrollBar.LegendCalcSize(Sender:TCustomChartLegend; var ASize:Integer);
if Active and ShouldDraw(R) then // SegFault
Inc(ASize,Size+1);
R = (-14680065, -14680065, -14680065, -14680065, (-14680065, -14680065), (-14680065, -14680065))
Anyone here that have had simililar problems or know how to fix this?
Frode
Post by Narcís » Fri Aug 26, 2005 9:04 am
Hi Frode,
It works fine here using code below and latest TeeChart version available. Does this code works for you? Could you please modify it so that or send an example we can run "as-is" to reproduce the problem here? You can post your files at [url]news://www.steema.net/steema.public.attachments[/url] newsgroup.
var
  LegendScroll: TLegendScrollBar;
  LegendScroll:=TLegendScrollBar.Create(self);
  LegendScroll.ParentChart:=Chart1;
  Series1.FillSampleValues(50);
