When is this ColorGrid bug fixed?
wktk
Post by wktk » Mon Dec 19, 2005 2:16 pm
Hi.
StevP posted this topic at 28 Sep 2004 21:42.
A ColorGrid's data points do not align with the axis lables if the grid is zoomed or scrolled. For example, add 10 x 10 data points to a grid. Scroll the grid to the right. When the first data point has scrolled from the far left X axis edge to about the center of the grid, the width taken by one unit of data is now more than one unit wide within the grid. Same if scroll vertical. Also can be observed if the grid is zoomed. There the grid does not align with the axis lables.
When is this bug fixed?
Post by Narcís » Mon Dec 19, 2005 4:19 pm
Hi wktk,
I can't give you a date for when this issue (TV52010537) will be fixed. However, I've increased its priority on our defect list to be fixed ASAP.
