[TChart] Customize TEditCha form ?
bertrod
Post by bertrod » Mon Jan 30, 2006 8:27 am
In the TEditCha form (the one that let us customize all the properties of the charts, with many tabs and subtabs), I would like to know if it is possible to remove some of the properties.
I could change few things in the TEditCha.pas file, but I can't find how to add or remove properties on the form. Is it possible ?
Post by Pep » Fri Feb 03, 2006 5:28 pm
yes, this could be done if you are source code customer. In this case you can edit the TeeChart package files, and modify (editing the Form editors and adding or removing some options). Once you modify all you want you will have to recompile/install the TeeChart pro sources/components.
