DepthAxis position
Post by Pep » Fri Feb 20, 2004 10:01 am
Hi Mochi,
(1)
Are you trying to move the depth axis along x direction or along z direction? If you're trying to move it along x direction, then you should use the PositionPercent to move it around. On the other hand, if you're trying to move it along y direction (vertically), then you should use the ZPosition. I've tried both properties (using v6.01) and it worked just fine.
(2)
Yes, you're correct, it's a bug, I've added it on our defect list and a fix for it will be considered to inclusion for the next releases.
Marjan
Post by Marjan » Wed Feb 25, 2004 10:40 am
Hi, Mochi.
Yes, you're correct. If you change depth axis z position, only the axis line and ticks position is changed. Axis label are still positioned at the same coordinates. One for our wish/to-do list for next release.
Marjan Slatinek,
DTech
Depth axis moved but the ticks, numbers, title do not move
Post by DTech » Wed Nov 10, 2004 5:44 pm
I'm experiencing the same problem and was wondering when the fix is expected to be in a release. With the code below, the Depth axis is moved but the ticks, numbers, and title do not move.
.Axis.Depth.Title.Caption = "DEPTH"
.Axis.Depth.Visible = True
.Axis.Depth.Otherside = True
.Axis.Depth.ZPosition = 100
Thanks, DTech
Post by Pep » Fri Nov 12, 2004 12:20 pm
yes, it's on our defect/wish list to be reviewed for the next maintenance releases.
