D7:dclstd70.bpl violation after TeeChart6 installation
tacq
Post by tacq » Tue Feb 24, 2004 8:18 am
After installing TeeChart601Delphi7 on D7 the dclstd70 package generates an access violation ; address of 0000000.
I've also had this on another box (which I never tried to resolve thou).
If I now remove all packages and just tries to inlcude the dclstd package, i still get the same error - but this did occur first until after I installed teechart.
Is there any known issues that could cause this? I will now start to reinstall everything starting with D7.
Post by Pep » Tue Feb 24, 2004 12:17 pm
which is the complete error that you're getting ?
Marjan
Re: D7:dclstd70.bpl violation after TeeChart6 installation
Post by Marjan » Tue Feb 24, 2004 4:46 pm
8573774 wrote:After installing TeeChart601Delphi7 on D7 the dclstd70 package generates an access violation ; address of 0000000.
Are you using Delphi 7 Personal version?
Marjan Slatinek,
tacq
Further info
Post by tacq » Wed Feb 25, 2004 7:14 am
Hi!
Ive now reinstalled everything, but instead I now used the sourcecode and recompiled it while adding the packages. Its now fully workin but interestingly is that I did have the very same problem on another box recently.
I do believe it could be something that is caused by some of the other packages I have installed that also is using Tee, even if the access violation doesnt occurr until I installed Tee.
Since installation takes quite some time and I now have it running I will not investigate this further (TeechartPro 6.01 / Delphi7 Pro)
