installation problems - Teechart7 for BCB 6
yashab
Post by yashab » Fri Mar 12, 2004 5:41 pm
I use BCB 6 SP 4 Professional . I reinstalled clean copy of BCB before
installing TeeChart.
Installation of TeeChart7 without source failed with the following error:
EXCEPTION:
Can't load package
C:\PROGRA~1\STEEMA~1\TEECHA~1\BuilderC6\Bin\DclTee7C6.bpl.
The system cannot find the file specified
I checked and the DclTee7C6.bpl does exist in
Marjan
Post by Marjan » Sun Mar 14, 2004 4:16 pm
Hi.
Is the required bpl file in the path specified by the installer ? If yes, have you tried to manually install it in BCB IDE ? This can be done by checking the check box in front of the package.
Marjan Slatinek,
yashab
Post by yashab » Thu Mar 18, 2004 11:50 am
I did the following:
1. Removed all TeeChart packages
2. Copied all *.bpi, *lib, *.bpl into CBuilder folders
3. Added DclTeePro7C6.bpl
Now it seems to compile and run fine.
Questions:
1. Is DclTeePro7C6.bpl rigth choice? There is also DclTeeProStd7C6.bpl and DclTeeStd7C6.bpl.
2. Do you plan to fix the setup? TeeChart6 setup didn't worked too you promissed to fix it in the next version
Marjan
Post by Marjan » Thu Mar 18, 2004 12:17 pm
Hi.
These are the BCB6 Standard packages - install them only if you're using BCB Standard. If you're using BCB6 Professional or Enterprise version, install The DclTeePro7C6.bpl package.
Yes, sure. For v7 we did several changes in the installer, but apprently there are still some problems.
Marjan Slatinek,
