Format of X-Axis-Labels
Mauritius
Post by Mauritius » Wed Feb 21, 2007 3:19 pm
I have charts with DateTime-X-Axis. The format for the Axis-Labels is 'dd'. If i show the chart on the screen the display is correct.
Now i want to generate a PDF-Dokument with QReport in the Background. If the frame with the Chart is Visible on Screen all works fine. If the frame is not currently visible all without the format of the X-Axis-Values is correct. The X-Axis-Values are saved in PDF-Dokument as big integer. I think its the Integerrepresentation of the date.
Did anyone have an id?
