Scaling Max value less than 1
Jeff S
Post by Jeff S » Fri Apr 13, 2007 4:32 pm
When I try to set the Max value for scaling on the left axis to < 1 , say 0.4. it seems that Teechart automatically resets the value to 1 and the left axis ranges display from 0 to 1 and not 0 to 0.4.
Setting the Max value > 1 scales perfectly.
Any help greatly appreciated.
regards,
Trev
Post by Yeray » Mon Apr 16, 2007 8:09 am
Hi Trev,
We couldn't reproduce your problem here using teechart 7.07. What version are you using?
The following code works for us:
Chart1.Axes.Left.AutomaticMaximum := false;
Chart1.Axes.Left.Maximum := 0.4;
Also you can try to type casting as follows:
Chart1.Axes.Left.Maximum := (double)0.4;
If your problem persists, could you please send us a simple example project we can run "as-is" to reproduce the problem here?
You can post your files at news://www.steema.net/steema.public.attachments newsgroup or at our upload page
Jeff S
Post by Jeff S » Mon Apr 16, 2007 10:25 am
Thank you for the response. I finally got it working. It was a logical error in my own code.
regards,
Trev
