Data only appears in middle 2/3 of the chart
Post by Pep » Wed Mar 24, 2004 4:02 pm
which TeeChart Pro version are you using ?
I've just test it here using the latest TeeChart Pro v7 with Delphi 7 and works as expected.
Could you please tell me the steps to reproduce the problem ?
Marjan
Post by Marjan » Tue Mar 30, 2004 1:32 pm
Hi, Mochi.
Thanks for the example - I'm getting the same results. I'll log this to our bug list so that it can be addressed in next release. In the meantime a workaround is to manually define axis scale by
a) calculating series min/max value
b) using chart axis SetMinMax method to set axis scale.
In your case:
With Series1 do
  GetHorizAxis.SetMinMax(XValues.MinValue,XValues.MaxValue);
Marjan Slatinek,
