BarSeries and mbSelfStack
AHa
Post by AHa » Fri Oct 19, 2007 10:00 am
I have a chart with some BarSeries that are displayed with MultiBar:=mbSelfStack.
Is it possible to display the Series-name under each BarSeries-Stack?
I ckecked BottomAxis.LabelStyle, but there is no option for the seriesname.
I also used GetAxisLabel, but it is only called for each SeriesValue.
If I have 5 Bars and each Bar has only 3 Values GetAxisLabel is called only 3 times and I can place the seriesname only under 3 Bars.
Also if the series-count is larger than the value-count of the bars they are overlapped. It can be corrected with BarWidthPercent, but can this calculated correct by default?
Andreas
Post by Narcís » Fri Oct 19, 2007 2:11 pm
Hi Andreas,
Could you please send us a simple example project we can run "as-is" to reproduce the problem here and let us know the TeeChart version you are using?
You can either post your files at news://www.steema.net/steema.public.attachments newsgroup or at our upload page.
AHa
Post by AHa » Mon Oct 22, 2007 9:15 am
I have uploaded the file "Tee7SelfStack.zip" created with Delphi 7 and TeeChart 7.05.
The problem should be visible at design- and run-time, if the datavalue-count is smaller than the series-count.
The "Series"-Title should be visible on the axis, because I need to display other things in the legend.
Andreas
Post by Pep » Wed Oct 31, 2007 12:38 pm
Hi Andreas,
I think that the best (and easy) way to accomplish would be by using the Custom Axis labels feature, simply use the following code at the end of the FormShow :
  Chart1.axes.Bottom.items.Clear;
  for i := 0 to Chart1.SeriesCount-1 do
    with Chart1.Axes.Bottom do
      Items.Add(i,'Series' + inttostr(i));
Yes, it's a known problem, for the moment there's not an automatic way to fix it, it must be done as you said by using the BarWidthPercent.
