Is there a way to set TChart OnClickSeries mouse margin? I'm using the OnClickSeries event, but the mouse has to be right on the Series to receive the event. I'd like to change this so it is easier to click on a series.
-Bill
Series On click margin
Hi Bill,
You can achieve what you request doing something like this:
var i, j, tolerance: Integer;
p, l0, l1: TPoint;
tolerance := 10;
p.X := X;
p.Y := Y;
for j:=1 to Chart1[i].Count-1 do
l0.X := Chart1[i].CalcXPos(j-1);
l0.Y := Chart1[i].CalcYPos(j-1);
l1.X := Chart1[i].CalcXPos(j-1);
l1.Y := Chart1[i].CalcYPos(j-1);
if PointInLine(p, l0, l1, tolerance) then
Chart1.Title.Text[0] := 'Series' + IntToStr(i+1) + 'clicked at point ' + IntToStr(j);
break;
Hi BE,
I'm afraid there's not such an option. Acutally, the PointInLine method I suggested is a TeeChart method, not Delphi's. TeeChart uses series's Clicked method for determining if they are being clicked or not.
Re: Series On click margin
I was just wondering if you have introduced a Tolerance parameters for seriesClick in version 8 of TeeChart, or if I should still use the same function shown above ?
Thank you !
Thank you !
Hi bertrod,
I don't think this (TV52014661) has been implemented in v8. You can what has been implemented recently in the release notes.
