Checking count of items in series after zoom
guzial
Post by guzial » Wed Apr 23, 2008 8:28 am
Hello
i have problem
i would like to show marks but in special conditions.
When chart is in 100% zoom i would like automatically hide marks because there is to much points and showing marks is not useful. So my problem is to check number of showing points in series and if it less than X i would like to set marks to visible. Is there any way to do it?
thanks in advance
Post by Narcís » Wed Apr 23, 2008 9:40 am
Hi guzial,
You can do something like this:
  Series1.FillSampleValues(1000);
  SetMarksVisible(Series1);
procedure TForm1.Chart1UndoZoom(Sender: TObject);
procedure TForm1.SetMarksVisible(Series: TChartSeries);
  Chart1.Draw;
  Series.Marks.Visible:=not (Series.VisibleCount>20);
guzial
Post by guzial » Thu Apr 24, 2008 6:55 am
what about TGanttSeries ?
Post by Yeray » Mon Apr 28, 2008 9:06 am
Hi guzial,
Yes, there seems to be a bug for Gantt series because VisibleCount doesn't seem to return the correct value. I've added it to the wish list to be fixed in further releases (TV52013013). But here you have a workaround that works fine for me here:
var i, nInRange: Integer;
  Chart1.Draw;
  nInRange := 0;
  for i:=0 to Series.Count-1 do
    if (Series.YValue[i] > Chart1.Axes.Left.Minimum) and (Series.YValue[i] < Chart1.Axes.Left.Maximum) then
      nInRange := nInRange+1;
  Series.Marks.Visible := not (nInRange > 10);
  Series.Marks.Clip := true;
