TCursorTool - Click Tolerance and movement
moelski
Post by moelski » Tue Jun 10, 2008 6:35 am
Hi !
We use TCursorTools for measurement purpose. We calculate the x / y differences between two cursortools -> dx/dy.
This works nice but I have a problem with the clicktolerance. By default this is set to the value 3. If you move the cursor tool over the other cursor tool it hangs for a short while. And you can´t place the one cursortool over another one.
If you set Clicktolerance to 0 all works fine. But then you have a problem to "catch" the lines for moving.
So is there any way to disable the line "bouncing" if you use a clicktolerance > 0?
Post by Yeray » Tue Jun 10, 2008 8:52 am
Hi Dominik,
I suggest you to force the ClickTolerance of the non clicked cursor to 0 when dragging. And restore the default (3) when finish dragging.
  if ChartTool1.Clicked(X,Y) = ccBoth then
    ChartTool1.ClickTolerance := 3;
    ChartTool2.ClickTolerance := 0;
  if ChartTool2.Clicked(X,Y) = ccBoth then
    ChartTool1.ClickTolerance := 0;
    ChartTool2.ClickTolerance := 3;
procedure TForm1.Chart1MouseUp(Sender: TObject; Button: TMouseButton;
