Problems installing evaluation version of Tchart 7
channli
Post by channli » Fri May 28, 2004 12:04 pm
When I install the evaluation version of TeeChart v.7 for Builder 5 (using file TeeChart7Builder5.EXE) I get the following error message: "Cannot open file 'C:\Archivos de programa\Steema Software\TeeChart 7 for C++ Builder 5\CBuilder5\Lib\Tee7C5.bpk'. El sistema no puede hallar el archivo especificado"
What can I do?
Post by Pep » Fri May 28, 2004 2:58 pm
Hi Channli,
yes, the problem is the path in the installer is not correct (changed letter i.e. instead of CBuilder5 we use BuilderC5). A temporary solution is to manually add design time packages to BCB package list (can be done with couple of clicks. We'll fix this problem and post a new installers on our web site in the coming days.
