Question of TMapSeries Control
Calou
Post by Calou » Thu Apr 23, 2009 12:09 pm
Hi all
I want to know if we can modifier in the TMapSeries the map added with the map by default, in fact, what i need is a french map, but i had a error when i tied to delete all the other maps but the France, the control was correctly show in the visual editor, but it shows Luxembourg and Australia instead of France at execution. The another question is if the background of chart can also zooming with the events of mouse, or replace a shape file with a image is possible or not?
Thank you
Post by Yeray » Thu Apr 23, 2009 1:42 pm
Hi Calou,
1. Yes, you could load an europe map and delete the polygons with label different to "France":
var i: Integer;
  Series1: TWorldSeries;
  Series1 := TWorldSeries.Create(self);
  Chart1.AddSeries(Series1);
  Series1.Map := TWorldMap(6);
  for i:=Series1.Count-1 downto 0 do
    if Series1.Labels[i] <> 'France' then
      Series1[i].Destroy;
2. The easiest way to do this would be using Image Tool and assigning the series to the tool. Then the chart and the image should zoom together.
Calou
Post by Calou » Thu Apr 23, 2009 2:57 pm
That works
Thx :)
